Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Axial SCX-10
Thread: Will this fit to replace the TR steering links?
Old 11-22-2009, 09:31 AM   #1
Default Will this fit to replace the TR steering links?
Will this fit to replace the TR steering links? Will I need anything else?
http://www3.towerhobbies.com/cgi-bin...XUUX2&P=6#tech
Do the ax-10 and scx10 use the same front axle and steering setup?
Thanks
Wild Snapper is offline   Reply With Quote
Old 11-22-2009, 10:06 AM   #2
Yes the axles are the same on both kits, and I do believe the stock steering setup is the same. also in your signature you know that Futabas system is Fasst not fast right?
NeoK5Driver is offline   Reply With Quote
Old 11-22-2009, 10:31 AM   #3
I like to #*&^
yup same axles same steering link 106mm
2500hdon37s is offline   Reply With Quote
