| | #1 |
| Quarry Creeper Join Date: Nov 2005 Location: Los Angeles, CA
| i plan on installing a motor capable of 25-30 mph just for fun and was wondering if the scx10tr had a sort of drag brake or something like that 2 help not let it roll around frely while crawling. my point gettin 2 if i put a motor that fast n let off the throttle will it like slam into drag/breake?? thanks! |
| Sponsored Links | |
| | #2 |
| I wanna be Dave ![]() Join Date: Jan 2005 Location: Hueytown, Alabama
| No, the drag brake is all in the ESC. I doubt the rtr esc has a drag brake. |
| | #3 |
| | #4 |
| Rock Crawler Join Date: Aug 2008 Location: Portland, Maine
| No kind of drag brake at all. If you want that then buy an esc with a drag brake. The cheapest one is probably a rooster crawler esc in the for sale section here. I read 2 listed yesterday. |
| | #5 |
| ohh ok. so i wana mainly focus on slow crawling i should deff. have a esc w/ drag brake? |
| | #6 |
| Pebble Pounder Join Date: Nov 2009 Location: Twin Cities
| Correct me if I am wrong, but doesn't the axial ae-1 esc have brakes? It's not going to be a super crawler quality esc, but it's more than adequate for a backyarder. At $35 on amazon it's a pretty cheap esc and can handle a 15t motor. Quite a bit of bang for your buck IMO. |
| | #7 | |
| Jason from the Springs ![]() Join Date: Jun 2009 Location: Colorado Springs
Im sure they put the lower end electronics in the RTRs to keep the price down | |
| | #8 | |
| | #9 |
| Newbie Join Date: Dec 2009 Location: BFE
| I recently got an AX10 Scorpion RTR and I have to agree, the elec's in this suck. After cutting the foams and adding weight to the tires the servo hardly moves. It is supposed to be a HIGH TORQUE servo, hell a cockroaches fart has more power. The ESC is no better, especially in the cold. I wouldn't suggest the RTR or RTC for anyone due to the elec's. |
| | #10 |
| The axial ae-1 esc has 150a braking voltage and i picked on up off amazon for like 35. it'll handle 5-10 cells and down to a 15t motor. Not too shabby for a basic esc with reverse. Yes the rooster crawler is better, but it is at least twice the price. If you are gonna do backyard crawling the ae-1 is more than enough for your needs IMO. |
| | #11 |
| Rock Stacker Join Date: Oct 2009 Location: Fort Worth, TX
| I actually have a TR and the AE-1 speed controller just needs a CC BEC. The Axial AE-1 does not have a drag brake per-se, but it does have a "Hold Brake". What it does is if you are on a downhill run, you can hit and release the brake and it will hold/drag. As soon as you give a little forward throttle, it will coast again. If you back up as soon as you let off, the brake holds until you move forward or reverse again. Also it resets itself on every power up (you hear 3 beeps) so keep your throttle trim at 0 and your end points at 100% (it is not adjustable) Here is the instruction sheet from the Axial site: http://www.axialracing.com/ftp/pdfs/...1_AE-1_ESC.pdf This thing is rated for 5 to 10 cells but take my advice and get a Castle BEC. First test at Mikes Hobby Shop's new indoor crawler course (lots of loose rocks for wheels to hang up in) caused repeated stalls as the AE-1 ESC only has a 5V/1A internal BEC. As soon as I picked up the truck, it started working again. Once I installed the Castle BEC, no more stalls and the truck was able to power out of all situations where the tires could still get a bite except for once (I got it wedged really tight and the slipper kicked in). It really is a decent ESC on par with most $40 to $50 ESCs. One pet peeve is that my TR did not come with any instructions for the ESC. The AS-2 metal gear servo is also decent as it has about 90 oz of torque. The main issue is it pulls too many amps in a bind so you need a BEC. |
| | #12 | |
| On the lookout for Rocks ![]() Join Date: Mar 2006 Location: Monroe, Louisiana
| | #13 | |
| | #14 | |
| Thread Tools | |
| Display Modes | |
