Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Axial SCX-10
Thread: drive shafts..
Old 11-27-2009, 06:09 AM   #1
backwoods crawler..
mcreil41's Avatar
Default drive shafts..
what is a good aftermarket driveshaft for scx-10 that is not totally bankbreaking??
mcreil41 is offline   Reply With Quote
Old 11-27-2009, 06:11 AM   #2
Location: You will never find a more wretched hive of scum and villainy
traxxas stampede shafts... i have been using a set in my comp rig for over a year... troubles at all
DeweyCJ5 is online now   Reply With Quote
Old 11-27-2009, 06:13 AM   #3
backwoods crawler..
mcreil41's Avatar
bolt up or do you have to modify??
Old 11-27-2009, 06:20 AM   #4
bolt right in
i got this 6 pack and have given all of the extras away to friends that needed em
http://www3.towerhobbies.com/cgi-bin...?&I=LXJH85&P=Z
Old 11-27-2009, 07:24 AM   #5
I would go for MIP ( shaft for ax-10 ) ,those thing rock !
flybird is offline   Reply With Quote
Old 11-27-2009, 07:57 AM   #6
X 2 on the pede shafts, they hold up way better than stock axial shafts.
allgm1 is offline   Reply With Quote
Old 11-27-2009, 08:26 AM   #7
x3 on the Stampede shafts, been beating mine for months
Brett B. is offline   Reply With Quote
Old 11-27-2009, 08:38 AM   #8
Motorama Bound
EvilTwin v2's Avatar
All I ran on my Axial (before I went MOA) was 'pede shafts. I modified them, though, to make them even stronger. I found that after running for a while, the male shaft would start to twist a little, then the travel was rough or it would even stick.
so, my solution was to use a regular female on one end, then on the other, I would:
1. Cut the splined section off of the male shaft.
2. Cut a female shaft to a length so that it would allow full suspension travel.
3. CA glue the male spline section into the shortened femail shaft.
4. Install that section.
Now instead of a long section of male shaft exposed (the male spline section being the weak link that twists), there is only a very short section of exposed male spline shaft. Most of the male spline is within the female shaft sections (whether glued or free to slide).
I also preferred the Traxxas 'pede metal shaft ends to the Axials.
EvilTwin v2 is online now   Reply With Quote
Old 11-27-2009, 11:11 AM   #9
Location: Stuck on a Rig in the middle of nowhere Utah.
I like using the Maxx shafts. They pritty much can't be broken in this size of rig. They are also longer than the Ped shafts. So they don't twist eather. The only problem with this mod, is this makes the tranny outputs the weak link. And you could start breaking outputs. There are a few places selling upgraded outputs.
Here is the link.
Maxx Shafts made easy.
70duncan is offline   Reply With Quote
