12-03-2009, 12:02 AM | #1 |
Pebble Pounder Join Date: Nov 2009 Location: Monterey Bay, CA
| SCX10 steering
I have a SCX10 with Hand Bros servo relocator, and I'm having complications with the steering. Full left is allowed, but going full right, it doesn't go all the way. I checked the radio (2.4ghz 3pm) and everything is set perfect. This is however my first crawler, so maybe I built it wrong. I actually think it is maybe the servo. I don't have any servos around, so I used an old Digital Traxxas 2070 servo. Not enough torque huh? its rated at 125 oz.
12-03-2009, 12:32 AM | #2 |
Pebble Pounder Join Date: Mar 2009 Location: stayin fresh in the northwest
did you make sure to center the servo before mounting the horn?
12-03-2009, 01:05 AM | #3 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Also make sure the horn isn't hitting the frame as it will be close.
12-03-2009, 03:22 AM | #4 |
when the rc is off, I can manual steer it and there is no binding whatsoever. Its probably due to the geometry of the new linkages.
12-03-2009, 09:15 AM | #5 |
Pebble Pounder Join Date: Oct 2008 Location: albuquerque
I built my own frame mount and I am using the stock TR servo and I get a little more triw one way than the other. I think the reason is the internal limiting from turning anymore.
12-09-2009, 06:31 PM | #6 |
Newbie Join Date: Dec 2009 Location: Bowmanstown PA
I just finished installing the hand bros kit on my SCX10. I didn't have full left steering when I completed the build. After playing around with a few things, I found I needed to shorten the drag link. Perhaps if you are not getting full right steering you may need a longer drag link. If your servo is a ful 90 degrees and you still aren't hitting the driver side steering knuckle on the axle housing you probably should try a longer drag link.
