12-07-2009, 02:50 PM | #1 |
Quarry Creeper Join Date: Nov 2005 Location: Los Angeles, CA
| what are the shock limiters for?
and dont say to limit the shock i already kno that. but WHY would i want the shock to be limited? whats pros and cons of it n pros n cons w/ it off?? Thanks |
12-07-2009, 03:14 PM | #2 |
Newbie Join Date: Jan 2009 Location: SLC
I put a limiting strap on my shocks to keep them from hyper-extending and popping the tops off.
12-07-2009, 03:19 PM | #3 |
ts just to limint flex but they work just fine with out it
12-07-2009, 03:28 PM | #4 |
I joined the Band! Join Date: May 2009 Location: anaheim
I think axial limited them cause the shafts they use in the stock shocks are too long. That and maybe with the limiters in it gives the truck a more scale suspension travel. All I know is I took them out to get better performance
12-07-2009, 03:34 PM | #5 |
| nope the shock shaft is the correct length you can compress them all the way with no trouble, but it may be a little more scale for travel but eh its just a little travel
12-07-2009, 04:00 PM | #6 |
Interesting my rtr shocks done compress all the way. Maybe too much oil or air in them. Doesn't matter as I switched to prolines shock and they are awesome
12-07-2009, 06:16 PM | #7 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
That is usually the result of too much oil. There is a thread in here somewhere on how to properly build the stock shocks that if you follow to the T, will give you perfect performance every time.
12-07-2009, 08:24 PM | #8 |
I guess when I build my trail honcho kit I just won't install the limiters on the shock shafts!
