12-23-2009, 04:42 AM | #1 |
Pebble Pounder Join Date: Jan 2008 Location: westfeild IN
| wheel weight
i have a few Qs about how you guys are running your rigs. i got some stick on lead weights. i was wondering how much you guys are running F/R? i was thinking of just going 3 1/2oz per wheel (b/c thats what it come out to when i fully wrap the wheel) i have seen in the AX10 fourm that they run more front than rear is that the same in the scale? i was going to do the same all the way around. also are you guys drilling holes in the rims on the SCX like the AX guys are? i would think it would let water in and never really come back out? thanks! |
12-23-2009, 05:15 AM | #2 |
Pebble Pounder Join Date: Aug 2008 Location: marlborough, ct
i run one wrap of lead chimney flashing on mine all the way around. If you love the throttle it well wear out stuff quicker and put more stress on your rig. Depending on what size tire. If you plan on any water dont drill holes. Its more of a pain than its worth if water gets in. I dont know how much weight i run, but lite rigs crawl better |
12-23-2009, 07:50 AM | #3 |
RCC Addict Join Date: Oct 2008 Location: PA
Front - (2) 1/8" vent holes and 6oz in each Rear - (1) 1/8" vent holes and 3oz in each I love my setup, works wonders Make sure you put your battery up front as well. Hope this helps. |
12-23-2009, 09:51 AM | #4 |
Rock Crawler Join Date: Jul 2009 Location: Little Rock, Arkansas
I run 5oz in each front wheel and 2.5oz in each rear wheel. I have drilled two 1/8" holes(on opposite sides of the wheel) in the center of each of the front wheels. I have drilled a single 1/8" hole in the center of each of the rear wheels.
