12-26-2009, 11:28 AM | #1 |
Rock Crawler Join Date: Jan 2009 Location: Jacksonville FL
| hpi bronco
so i got my scx all built and im trying to mount my bronco body on it i used the stealth mounts on the front but im using the regular mounts on the back my problem is that if i use the mounts for the stock body the bronco sits to low but if i use the mounts for the suv bodys it sits to high i know people have used the bronco on the scx before so how do you guys mounts them thanks |
12-26-2009, 11:40 AM | #2 |
Pebble Pounder Join Date: Nov 2009 Location: Twin Cities
There are many option. you can make your own mounts, modify the stock mounts, use ax10 style mounts (supports the sides) or i've seen one guy who mounted the body at the rear of the truck, basically had body mounts coming out the back of the frame. The options are almost limitless, decide what works best for you and be creative.
12-26-2009, 11:51 AM | #3 |
Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
OK i used the SUV mount with the extra body mount holders that come on the parts tree. i had to trim the rear bumper second mount (the one that snaps in) and drill the frame to 3mm used a extra set of screws and its mounted then i set ride height and trimmed the bottom of the mounts and heres a pic from the rear |
12-26-2009, 11:58 AM | #4 |
Nicely done!
