12-29-2009, 07:32 AM | #1 |
Newbie Join Date: Dec 2009 Location: spain
| scx10 wear
Hi to all, I am thinking to buy a SCX-10 to use it in sand. I live near a beach. I see that the pinion and the clutch are exposed. There is something to cover up? Do I have to worry? Thanks in advance, Nuevototem |
12-29-2009, 08:38 AM | #2 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
There is nothing I know of to cover it with but with a little lexan/polycarbonate some glue and scissors you could get a nice cover together. I would definitely want something to keep the sand out if running on the beach.
12-29-2009, 11:24 AM | #3 |
Hi to all, I am really surprised that the pinion and clutch are exposed to mud, sand, etc. Regards, |
12-29-2009, 12:19 PM | #4 |
Pebble Pounder Join Date: Nov 2009 Location: Monterey Bay, CA
| yeah, but its a crawler. I never found myself needing to pick out little grains of sand or silt out of the pinion or spur gear on my crawler. If you are really worried, wheel wells would suffice. But other than that, I can't see anything getting lodge in their unless your crawler was built for speed. But I doubt it with a crawler.
12-29-2009, 12:47 PM | #5 |
Rock Crawler Join Date: Oct 2008 Location: Somewhere near the lake in IL
Make some fender wells that will help dramatically. I made a set for mine from some 2.99 disposable lunch containers. I will also cut the sides out of a 2 liter pop bottle and zip tie them to the rock slider mounts to keep even more crud away, but depending on the conditions that can also be a nice shelf for stuff to build up you'd have to experiment with that. I've run mine on the beach a few times without any real problems. With the pinion and spur facing backwards it doesn't seem to be affected. The only real thing I would tell you to do that may be add a outerwears cover for the motor. http://www.outerwears.com/proddetail.asp?prod=202529 The motor tends not to like getting the fine sand particles in and around the brushes/bushing/bearings. |
12-29-2009, 02:30 PM | #6 |
Rock Crawler Join Date: Mar 2008 Location: lodi
look for benders original scx10 build. put some fenders in made from cd cases add some paddel tires a good fast motor and really kick up some sand Edit: here i made it easy for yea Updates on my SCX10......... |
12-29-2009, 08:03 PM | #7 |
Pebble Pounder Join Date: Apr 2009 Location: lake saint louis
when i used to race the original rc10 from back in the day, it had a dust cover for the pinion and spur not sure if the motor plate from an original stealth would fit? the trans. looks the same to me. but the only thing they were good for was collecting dirt in the motor and gears, and catching the pinion when it fell off. we always just threw the covers in the trash... they seemed to always do more harm than good... but that is my opinion, and my $.02
