| | #1 |
| Quarry Creeper Join Date: Apr 2006 Location: Norcal
| Almost done putting this one together ![]() ![]() I tried to get the body as low as possible so I sat for hours trying to use the stock parts and still achieve a low slung truck. Needless to say, I only found 1 way to lower the flatbed a little bit which was flipping the rear body posts around and installing them from the bottom instead of the top. This lowered the flatbed to rest directly on top of the frame (more strength possibly). For the front I did the badger mod and cut down the plastic posts the battery tray sits on to get the battery lower and more out of the way; I still have a bunch of adjustment up front for body position. ![]() I had some issues with the flatbed up near the top where it bolts to the cab, every time I tightened the bolts, the lexan on the cab began to cave in. It's hard to see in this picture but clearly the flatbed didn't match the contours of the cab. ![]() Here is my fix, all I did was shave plastic off the flatbed to match the cab. You can see that in this picture. ![]() Some people were saying their 645mg servos don't fit with the crossmember but mine seems to fit just fine ![]() With the steering, I was a little concerned that the link going from the servo to the driver side arm was putting too much leverage on the steering arm. What I ended up doing was putting the tie rod below the arm to somewhat get rid of the slop and it seems to have a little less play in it. This can be fixed by going with aluminum steering arms but I'm not at that stage yet :-P Has anyone had an issue with running them both on top of the arm? If not, I'll switch it back and keep the ground clearance. ![]() For electronics I decided to run a Tekin FXR, Integy 45t crawler motor, Traxxas TQ3, 7.2 NiMH, full Deans plugs, 645mg (YES! IT FITS!). I also have a 3 pack of pinions on the way, 13, 14, and 15t. Here's a few more artsy shots ![]() ![]() ![]() I can't wait to wheel it! Edit: One other thing I forgot to mention is the gas tank sticker doesn't quite fit right so a tip to anyone building the truck, paint the fuel tank instead of using the sticker ;) Last edited by generalee7; 12-31-2009 at 08:26 PM. |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Aug 2007 Location: Orlando
| Looks nice, what brand and shade of red is that? |
| | #3 |
| | #4 |
| Pebble Pounder Join Date: Mar 2008 Location: San Antonio TX
| looks |
| | #5 |
| RCC Addict Join Date: Aug 2008 Location: On a rock
| Looks really good.... really like it in that color...... |
| | #6 |
| Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
| wow that red really makes it stand out |
| | #7 |
| RCC Addict Join Date: May 2006 Location: China Grove, NC
| That is a great color choice. It looks great. |
| | #8 |
| Rock Crawler Join Date: Feb 2008 Location: Not sure right now
| The red really does make it look sharp. Great job on the build and all the info.. |
| | #9 |
| Thanks gents |
| | #10 |
| DIRTY SOUTH ![]() Join Date: Sep 2005 Location: Dirty South
| Nice looking Honcho, I like the red . Almost as must as the green on mine . |
| | #11 |
| Haters gonna Hate ![]() Join Date: Mar 2005 Location: In the Basement building Hiluxs and shit
| | #12 |
| Thanks a lot for the compliments! I think this body turned out to be my best one yet. I used to slap paint down and never had much luck but I took my time with this truck and the results show I also decided to ditch the TQ3 crap because I've read a bunch of people having glitching problems in combination with an FXR. So before I set the whole thing up only to be disappointed with the performance of the TQ3, I am going to sell it and pick up a DX3E once it comes out! More money but it's just what I am looking for |
| | #13 |
| Thought I'd update this thread since things have changed a bit Painted the stock beadlocks black, got a new body because the red one was beat to shit Rok Lox are kickass tires! I peel out all the time on the rocks and they just keep coming back for more. ![]() ![]() I suppose it's all over now, just started throwing some stainless tube into this thing. I'll be building new sliders and a flatbed too so stay tuned |
| | #14 |
| Pebble Pounder Join Date: May 2010 Location: albuquerque
| kick a$$ front bumper |
| | #15 |
| Rock Crawler Join Date: Aug 2009 Location: Denton, NC
| | #16 |
| Thanks! Continuing to mod... ![]() Summit 2 speed with jason's mount, pretty slick setup! Here is my cure for getting rid of the spring for the shifter. Paperclip worked wonders and it shifts beautifully ![]() Also have some 12mm wideners on the way, 2.2 Rok Lox and JConcepts Tense beadlocks |
| | #17 |
| | #18 |
| Quarry Creeper ![]() Join Date: Nov 2007 Location: Bay Area (RWC)
| I like it. |
| | #19 |
| .... ![]() Join Date: Aug 2008 Location: Northern, Mi
| | #20 |
| On the lookout for Rocks ![]() Join Date: Mar 2006 Location: Monroe, Louisiana
| Thread Tools | |
| Display Modes | |
