Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Axial SCX-10
Thread: scx10 will ax10 parts work?
Old 01-03-2010, 12:57 AM   #1
Default scx10 will ax10 parts work?
i want to get a scaler but i can get an ax10 for cheap from a friend
what parts can i use on the scx10 chasis?
i was thinking of getting a tcs x trail chasis and someone said to just get an scx10 chasis but i dont think i can use as many parts on the scx10.
if i get a tcs x trail chasis and the ax10 i will pretty much have everything i need right? any input would be appreciated
dranger962000 is offline   Reply With Quote
Old 01-03-2010, 01:01 AM   #2
GOT SCALE?
team3six's Avatar
You can use pretty much most of the items from an AX10, all you need is the SCX10 chassis or the TCS or whatever scale chassis you want to use.
you may have to change links sizes, shocks, a drive shafts, but yes pretty much anything on an SCX10 is interchangeable with an AX10, just different chassis.
team3six is online now   Reply With Quote
Old 01-04-2010, 11:17 PM   #3
I started out with a AX10 and made my own frame from 1/2' box tubing ripped down the middle check out my build thread
Hilux Truggy Build
scrapen is offline   Reply With Quote
Old 01-05-2010, 12:28 AM   #4
that is a pretty sick truck how much time do you have in that?
i was trying to go an easier route or more lazy route
Old 01-05-2010, 10:38 AM   #5
I dont know how long i worked on it for sure a couple weeks is all. I was actually pretty easy to make the frame if you have some basic tools to work with. if not you can buy the scx10 frame set for around $50
Axail SXC10 Frame Set
or
TCS Xtrail for $42
and just use all your ax10 parts
Old 01-05-2010, 01:25 PM   #6
I converted my ax10 to an scx10 also buying the frame kit. Also may aswell get you some new links since the ax10's are way longer than the scx'
kikcaffine is offline   Reply With Quote
Old 01-05-2010, 02:06 PM   #7
Depends on what body u use on the link lenghths and don't buy new links just cut yours to the desired length save some $
Old 01-05-2010, 06:30 PM   #8
I turned my ax10 to a scx10 all you need to change, 6x91 lower links, small 5mm spacer in the three link and i got some stock metal shockes and stock 1.9s then all i had to do was trim up the hubs to make them more narrow
general lee is offline   Reply With Quote
Old 01-05-2010, 10:18 PM   #9
thanks for the info now i will just have to choose which one it sounds like either way is a good idea
