| | #1 |
| Got Crawlers? ![]() Join Date: Dec 2009 Location: Colorado Springs
| I am looking at getting my first scaler. I really like the Honcho Kit, but I also like the fact that the TR has a shorter wheelbase. I want to build a 2 door JK wrangler, and I think the honcho wheelbase will be to wide. I know you can lengthen the wheelbase on the older scx kit, but is it just as simple to make it shorter? If i did go with the TR, then can I just swap the plastic for aluminum Axial parts from the old scx kit? I might go that route since the electronics are in there, and I can swap the links and shocks and such as i go. thanks for any input! |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Apr 2009 Location: Amherst, OH
| Sounds like you have it all figured out. If you get the Honcho you'll have a lot of unused things, but you could sell them to buy some electronics. Or at least fund some electronics. I'm kind of in the same boat as you. I plan on building a JK and I'm leaning towards the TR. It's not going to be my main rig, more of a loaner for people to come along with me. So I won't mind if the electronics suck for them Are you cutting down a 4 door into a 2? What is your finished wheelbase, or are you not that far into it? |
| | #3 |
| I don't mind the stock electronics to start, as I will probably rip them out later down the road. I am not that far into it, but I will probably cut down a 4 door into a 2 door. I want it to match as close to the real deal as possible though. |
| | #4 |
| I joined the Band! Join Date: Oct 2008 Location: Bay Area
| Have you looking into the TCS X-trail chassis? It might be what your looking for. |
| | #5 |
| I looked at their kit the other day, but it requires an Ax10, and I figure I would get the TR, and drive it while I work on the body and other items. |
| | #6 |
| I guess my question now is can I just swap the plastic parts like the links and steering on the TR for aluminum Axial parts from the old scx kit? |
| | #7 | |
| Pebble Pounder Join Date: Mar 2009 Location: Grants Pass, OR
http://axialracing.com/wordpress/200...r-to-aluminum/ | |
| | #8 |
| sweet! thanks that's excatly what I needed! |
| | #9 |
| No prob. |
| | #10 |
| Jason from the Springs ![]() Join Date: Jun 2009 Location: Colorado Springs
| Let me know if you ever want to check out any of my scalers, we can meet at Palmer Park sometime. I have the Honcho and a couple hard body Jeeps. I have had a couple SCXs and AX-10s converted to scalers |
| Thread Tools | |
| Display Modes | |
