Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Axial SCX-10
Thread: Project Tonka Toy
Old 01-09-2010, 04:11 PM   #1
Location: Somewhere between the Atlanic ocean and Mississippi river
Default Project Tonka Toy
well, I have this old Tonka dump truck, originaly i was gonna sell it, to to a collector in town, but he said it has no value because it had the plastic chassis, well, if it did, it doesn't any more, so since then it's been setting outside in the weather, so I thought I would finally do something with it, after some examning i discoverd that it should fit on my SCX-10 with some slite modification.
Here is where it's been, I got the idea at this exact moment
I cut the axles off, then removed the axle mounts with the Dremel, after i broke 3 grinding wheels on the last cut, one of which hit me in the arm, i decided to stop cutting for a while and grind them down smooth(ish), i cleaned all the spider webs and wasp nest, (it had been sitting in the snow for three days which is why i didnt worry about them until now), then drilled out wholes to put LEDs in later on for lights.
shadowtrucker95 is offline   Reply With Quote
Old 01-09-2010, 04:26 PM   #2
hmmmmm, interesting. will be keeping an eye on this.
nitro_star is offline   Reply With Quote
Old 01-09-2010, 04:48 PM   #3
Default Paint?
Not really in a hurry for an answer, but does anybody still make this shade of yellow? If they don't i'll just make do.
Old 01-09-2010, 04:51 PM   #4
ya i had some that was close I think it was called sun burst yellow maybe but i do know it was sold at wallmart and it was the only yellow that was in the wall mart brand paint hope that helps fi its not close enouf its only a buck but im sure its almost a 100 % match
hende is offline   Reply With Quote
Old 01-09-2010, 04:53 PM   #5
keep in mind that this is the paint that been on it since 1999, and has been sitting out side since last year.
Old 01-09-2010, 06:16 PM   #6
maybe take it into a paint place that does colour matching,even if you buy a cheap lil tonka to get the original colour???
Old 01-09-2010, 10:35 PM   #7
I've been thinking of just using School Bus Chrome, or just go to TSC and buy some yellow that looks good.
anyway, after more examination i found that the shock towers is the main place where it's hitting, so i removed the shock towers and it seems to fit...almost. well it's kinda obvious what needs to be done now, i think im gonna mount the body solid the the chassis, then cut out the area under the bed to put the battery, move all the other electronics under the cab, the top of the shocks to the chassis of the Tonka truck.
and two things I need some a opinions on:
go with 2.2s or keep the 1.9?
keep the 3 link or get leafs?
Old 01-10-2010, 12:09 AM   #8
go huuuuuuuuge on tires. something big, but still industrial looking.
aircooled67 is offline   Reply With Quote
Old 01-10-2010, 12:12 AM   #9
that body would be nice on the tamiya chassis. keep an eye out for tonka toyotas, sweet metal body.
Old 01-10-2010, 10:45 AM   #10
TexasSP's Avatar
Maybe it's just me but I think the RC4WD 2.2 Rock Crushers just scream dump truck.
http://www.rc4wdstore.com/2/product_...roducts_id=453
TexasSP is offline   Reply With Quote
Old 01-10-2010, 10:50 AM   #11
maybe they don't sream at me, but i will keep those in mind. and does anybody know a of a tranny that will work as good as the stock axial one, because it seems to be causing 90% of my clearance problems when mounting the body.
Old 01-10-2010, 07:11 PM   #12
went to Walmart today, got some Sunburst Yellow paint, some Flat black to "refresh" the plastic, and some primer and masking tape, may get it painted soon, also got some 3 in 1 oil to smooth up the hinge on the dump bed.
Old 01-10-2010, 08:41 PM   #13
TexasSP's Avatar
I think the RC4WD R2 Tranny is lower profile.
http://www.rc4wdstore.com/2/product_...roducts_id=280
There are dimensions listed on the page.
Old 01-10-2010, 10:52 PM   #14
I had that one in mind. seems to be used a bit.
Old 01-11-2010, 01:59 PM   #15
Thats what I used in my scx10 when I had body clearance issues with my Chevy SS hard body.
Plus with a few slight dremel modifications you can get the tranny to sit in the stock skid plate only downfall with it imo is not real good in muddy or wet situations
CRAWL UGLY is offline   Reply With Quote
Old 01-11-2010, 02:05 PM   #16
Default More lights to wire up later on....oh well.
You know those 2 extra light buckets that come with the Pro-Line light bar? I found a use for them.
sorry for the bad pics, I've been shooting all my pics with my cell phone. I'm going of the crazy image that some body ever comes up with a 4wd conversion and lift kit for mining dump trucks. so i figured it needed more lights.
Old 01-11-2010, 06:03 PM   #17
i gotta watch this build looks promising
spike is offline   Reply With Quote
Old 01-11-2010, 06:26 PM   #18
Looking forward to seeing this progress. If ya want to know what NOT to do, follow this build http://www.orcrc.com/forum/showthread.php?t=3133 Can you say FAIL? . Picture a fat kid playing on one of these.Click the image to open in full size.
Yah, it was worse than that lol.
solomon7 is offline   Reply With Quote
Old 01-11-2010, 06:58 PM   #19
ways that build fails:
1. that tonka truck pobably would have had some value if it was cleaned up.
2. its a tonka truck, you can't make a flatbed tow truck out of it!
Old 01-11-2010, 07:24 PM   #20
My favorite part of that is even if you accept the fact that he slaughtered a tonka truck and made it into a car carrier, when a car is on there the ramps hit the wheels
NeoK5Driver is offline   Reply With Quote
