01-09-2010, 08:06 PM | #1 |
Rock Crawler Join Date: Mar 2007 Location: babylon, long island ny
| honch front axle clearence problem??
I just picked up a new honcho built it up and was messing around w. the front suspension. I noticed i wasnt getting full suspension travel because the servo horn kept getting jamped up in the front chassie brace.* not the bumper mount the one behind it* . I had to shave off some of the brace for it to get full travel. Im running a jr servo and i know my friends scx-10 didnt have this problem. anybody else run into this?
01-09-2010, 08:31 PM | #2 |
Rock Crawler Join Date: Nov 2009 Location: Southern, IN
the honcho has a longer wheelbase and axial seems to have overlooked the interference problem, everyone is either trimming or removing the front crossmember. best way in my opinion is a chassis mounted servo.
01-09-2010, 09:47 PM | #3 |
Rock Stacker Join Date: Sep 2006 Location: Liberty
I used the mount's that only mount to the lower hole in the servo they are set back more. Other's have put a metal arm on their servo and that has fixed the clearance issue's also.
01-09-2010, 09:55 PM | #4 |
www.team3sixrc.com Join Date: Mar 2008 Location: Scalerville
Hand Bros. will release their chassis servo mount for the Honcho soon. But yes other shave backed up the servo on the mounting plate. read through this thread. Hand Bros Head "HONCHO" Last edited by team3six; 01-09-2010 at 09:59 PM. |
01-10-2010, 11:57 AM | #5 |
I wanna be Dave Join Date: Dec 2006 Location: here
I just trimmed the servo mounts (plastic parts) about a 1/16" cleared fine |
01-10-2010, 04:15 PM | #6 |
Rock Crawler Join Date: Jan 2009 Location: Jacksonville FL
i also had this problem but nothing the ka-bar couldnt fix |
01-11-2010, 05:58 AM | #7 |
i planned on eventually either setting up my own chassie mounted servo or gettign the handbrothers one.... but i wasnt sure if it was a frequent problem or not
01-11-2010, 08:20 AM | #8 |
RCC Addict Join Date: May 2006 Location: China Grove, NC
Just use TLT servo mounts and the problem goes away.
01-11-2010, 09:23 AM | #9 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
did away with my cross brace,since i made my own setup,didnt use the batt plate. |
01-11-2010, 09:44 AM | #10 |
Rock Crawler Join Date: Apr 2008 Location: Calgary
I had this problem with an Ace 1015 servo. I had the Aluminum Pro arm that not only screws on but also has the two clamp screws that literally clamp the servo down. Once I tighted those up, I pulled the main screw out. It all clears and it will hold just fine.
