01-15-2010, 03:18 PM | #1 |
Pebble Pounder Join Date: May 2007 Location: Little Rock
| What else is left?
I am out of ideas of what I can do to make my Scx10 tr crawl better. (for cheap) Other than tires. or steel front bumper. Or Hands Bros steering. Current mods: Rooster Crawler Novak Fifty-Five motor Alluminum Steering Rods Weighted tires 4-link Rear Front battery mount 14t pinion Custon mount from ESC and I/O switch. |
01-15-2010, 04:37 PM | #2 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
tires,stronger steering servo,alum servo arm,alum knuckles,alum carriers, delrin lower links(see jeepial). other than that,seat time is what will help most. |
01-15-2010, 04:50 PM | #3 |
I have a 212oz servo sitting around do you think that would be an upgrade or should I just leave that if I break one. Also what will the aluminum knuckles and arms do for me, in terms of crawling? I'll take to jeepial about some lowers. Thanks for the info |
01-15-2010, 05:01 PM | #4 |
the stock servo is crap, i cant apply thr and steering or the axial esc shuts down. i run a hitec 645mg servo @130 oz yours will be a big upgrade. alum knuckles and c's wont bend or twist like the stock plastic ones. just wait till summer..when it gets hot...your stock knuckles will bend REAL easy then. and you can get the histeer knuckles that will raise your tie rod. the ones i have from vp raise the tie rod @1/2 in from stock location. |
