01-17-2010, 08:33 PM | #1 |
Quarry Creeper Join Date: Jan 2006 Location: North Charleston
| the king of blackfoots
build idea, if this ever gets off the ground. i want to do a scaler, my issue is that i have no way to fab stuff so i was wondering about the feasibility of this. i want to get a honcho, and a king blackfoot body, maybe 2, if need be. leave the hilux front end off and remove the bed from the black foot and use the stock honcho bed. how much of a head ache would this be? |
01-17-2010, 08:37 PM | #2 |
Pebble Pounder Join Date: Oct 2006 Location: Ogden, Utah
wouldn't be that hard but the only problem is the blackfoot body is kinda small and might look kinda goofy with the honcho back half...
01-17-2010, 08:40 PM | #3 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Yeah, I am sure it would be small with the back half. I thought about using the whole blackfoot body the other day though. :-P
01-17-2010, 08:40 PM | #4 | |
BTW, EVERYBODY has a way to fab stuff, you just have to get creative. You can make do with very cheap tools. I did it for a long time during college. | |
01-17-2010, 08:59 PM | #5 |
no tools, limited to no workspace, and no money to aquire either. i will figure out something. i just want to use that bed, just another body. also the reason i was thinking about 2 bf bodies was to do an extended cab, is the problem length width or overall? i cannot find measurements for the honcho.
01-20-2010, 05:44 AM | #6 |
Quarry Creeper Join Date: Aug 2007 Location: Montrose
I had the same idea planned for a smiliar build but got measurements and the Honcho is as WIDE as the Blackfoots wheelbase...LOL. If you threw some narrower axles under it it would work. The blackfoot has the same identical wheelbase as the Tamiya Bronco body. You can use some of those builds for refrence on size. I mounted a Bronco body on a shortened REGULAR scx and had to shorten it ALOT. My opinion and what I was going to do...Extended cab blackfoot cab with some sort of Flares to widen it out a bit. You would have to somehow narroe the rear Honcho cage down. I deccided tto build a Bronco and switch out bodies here and there form the Bronco to the Blackfoot. |
01-20-2010, 05:50 AM | #7 |
Rock Crawler Join Date: Mar 2007 Location: babylon, long island ny
i thought that fabbing stuff was hard but once i treid it i eventually got the hang of it..
01-20-2010, 05:17 PM | #8 |
i was thinking the black foot because not many people have used that body. and i am considering other options, thank you for the support, is teh f450 body the same size as the hilux which seems to be used often.
