01-18-2010, 10:44 PM | #1 |
Quarry Creeper Join Date: Apr 2008 Location: Clay, Alabama
| Compare Honcho and "normal" SCX10
Other than the body/flatbed, what is the difference in a normal scx10 and a Honcho? Is the appearance the only difference? edit - I finally found the comparison on Axial's site - looks like the Honcho has almost a 1" longer wheelbase, all hex hardware, and a bunch of light buckets... Is that all of the difference? And how is the wheelbase stretched? How tough would it be to convert the SCX10 to match? Last edited by rctoyguy; 01-18-2010 at 10:50 PM. Reason: found info |
01-18-2010, 10:45 PM | #2 |
Rock Stacker Join Date: Oct 2009 Location: Auburn
I believe the honcho has a longer wheelbase. I think it's made longer just with longer links but i'm not sure.
01-18-2010, 10:53 PM | #3 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
Compared to the kit ... It comes with a front bumper Sliders Longer links (wheelbase) Fullsize functional spare tire Some lights Check it out: http://www.axialracing.com/ftp/scx10-kit-v2/ |
04-04-2011, 10:03 PM | #4 |
Newbie Join Date: Mar 2011 Location: anywhere my two feet are standin.
i got the RTR honcho an it came with a bunch of different parts. I shortened the wheelbase to fit a proline XJ with the links that came with it |
04-04-2011, 10:06 PM | #5 |
Newbie Join Date: Mar 2011 Location: St.Clairsville
I got a rtr kit also and im in the process of regreting it now i really wish i would have bought the kit so i could have customized my electronics. I like the way they are but i hate leaving things stock |
04-05-2011, 06:01 PM | #6 |
RCC Addict Join Date: Mar 2011 Location: easton
i got the honcho kit, its not that hard to put together, even though it was the first rc kit i ever did, just cant decide on what color
04-06-2011, 12:55 AM | #7 | |
Quarry Creeper Join Date: Feb 2011 Location: San Diego
04-06-2011, 02:06 AM | #8 |
Rock Crawler Join Date: Apr 2006 Location: Hartland, MI
There are some subtle differences along with the wheelbase difference (which is primarily just longer links). The battery placement is different, in the back on standard SCX but up front on the Honcho. Frame is the same, axles, shocks, etc same. Upgrades on the kit vs. RTR are worth it, IMO.
04-06-2011, 06:29 AM | #9 |
Rock Stacker Join Date: Mar 2011 Location: Canada, Quebec, Montreal
metal links insted of plastic links
04-23-2011, 10:58 AM | #10 |
Newbie Join Date: Apr 2011 Location: North Jersey
When they say mixed hardware versus all hex hardware what's mixed about it?
04-23-2011, 11:23 AM | #11 |
04-23-2011, 11:53 AM | #12 | |
Quarry Creeper Join Date: Jan 2006 Location: North Charleston
04-23-2011, 05:58 PM | #13 |
Rock Crawler Join Date: Jan 2011 Location: Okanagan
The honcho kit I bought, does not have the links to fit the dingo body. all hex, the only phillips you need is to mount the servo on the plate. the kit has metal 3 link, metal steering links, no electronics, no leds, just a pile of light buckets. the honcho comes with a skid plate on the bumper, dingo doesn't. the kit doesn't come with the 4 link truss bar. oh and no allen keys in this kit neither, so make sure you buy a 1.5mm 2.0mm and 2.5mm allen keys, if you strip the allen key cut it off with dremel and reuse. When you build the kit, when you get to the shocks, cut the bump stop its a 1cm rubber that goes between the bottom of the shock and stops the shock from supressing fully. you can cut that 1/4 off of it and only use 1/4 of the bump stop. now the dingo has plastic links like said above, but also comes with spare links to mount the honcho body. also comes with pre-made LED kit and basic LED system for 2 red and 2 white lights. plastic steering links. and comes with a working fully functional 5th proline wheel on beadlock rim, same as honcho. My buddies TR dingo also came with the AE-1 ESC not the ae-2 and also came with the new 2.4ghz radio system. either way your going to have to fork up around 75-100 bucks depending wher you shop for ESC/radio for the kit. or you will spend the same amount of money buying aluminum steering links and aluminum 3 link kit. because the plastic gets chewed up pretty easy, nice they added a free plastic in the TR dingo hope that helps out a little... OH if your ESC runs hot out of the TR dingo box. make sure you check your servo. the servo that came in my brother in laws TR dingo was defective and was drawing way too much power for its own good. but 10 day warranty covered that. |
