01-22-2010, 09:28 AM | #1 |
Rock Crawler Join Date: Sep 2009 Location: Orangevale
| Pinion help
Hey I have a Tekin 55T crawler motor and the 12 th pinion will not fit if I put the set screw toward the motor it will hit the motor and the spur will not be lined up with the splines, if I flip it over the set screw will not clamp down on the shaft is there a better pinion or do I have to grind down the back side so it will slide on the motor more. Thank for the help |
01-22-2010, 09:57 AM | #2 |
Quarry Creeper Join Date: Nov 2005 Location: Los Angeles, CA
u can search other pinions n just by the looks of it ull b able 2 tell if it will work or not. what i would do i grind down or cut the excess so that it will fit. cheep easy fix! just gont get way 2 close to the setscrew hold so that when u tighten the setscrew it wouldent crack. |
01-22-2010, 02:33 PM | #3 |
Rock Crawler Join Date: Jul 2007 Location: Portland,OR
Get 6 or 12 3mm washers and stick them under the spur between it and the plate it screws to. It'll space it out 1 (6 washers) or 2 (12 washers) Millimeters, giving you enought room. Don't just put washers where the 3 screws hold the spur to the plate, fill in all the gaps/holes with a washer that way the spur will stay straight. Ya may need 3 slightly longer screws for this. In this way, you can space out the spur like that 3mm+ before you don't have enough thread to torque down the center nut. You could also make a lexan spacer between the motor and motor plate if needed, but spacing the spur is easier. |
01-22-2010, 02:44 PM | #4 |
Rock Crawler Join Date: Apr 2009 Location: Pa
A 12t pinion is pretty small for a 55t motor, will be very slow.
