01-22-2010, 11:09 AM | #1 |
Quarry Creeper Join Date: Nov 2005 Location: Los Angeles, CA
| anybody else's stock honcho springs too stiff?
I think my honcho springs are a bit 2 stiff. i can't* use up all the suspension without another tire comming off the floor... do the springs just need 2 b broken in or what? any solutions other then having 2 buy softer springs? cheep fix/trick? Thanks Last edited by yellowpasta2000; 01-22-2010 at 11:30 AM. |
01-22-2010, 11:18 AM | #2 |
That's usually the way I want it. I think the suspension is just about right.
01-22-2010, 11:23 AM | #3 |
Rock Crawler Join Date: Dec 2005 Location: Hawaii
My stock suspension works fine, in fact I have the collars adjusted all the way to the top. I'm running 3oz of weight in each wheelso that may be helping.
01-22-2010, 11:25 AM | #4 | |
Diggin' the new SCX10 II! Join Date: Mar 2004 Location: Norcal
If you can't do that then add some wheel weight to keep the tires planted if you haven't already done so. | |
01-22-2010, 11:26 AM | #5 | |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
you mean the shocks are fully compressed,maxed to the bump stops, and the tires dont come off the ground,unless you lift the tire that is being raised a lilbit higher and then the rear of the truck starts to lift? if you followed the instructions on building the shocks,red spring on top,green on bottom. then everything is normal. if you left out the bump stop(lil black silcone tube), then you will have alot more travel in your suspension. jez im slow... by the time i got done typing 4 people responded. Last edited by ROLANDROCKSHOP; 01-22-2010 at 11:29 AM. | |
01-22-2010, 11:32 AM | #6 |
Sorry guys i meant to put "cant"- i can't* use up all the suspension without another tire comming off the floor. yea i think the solution would b wheel weights. i have about 7-10mm of suspension left b4 another tire unplants from the floor. thanks 4 the help guys! |
01-22-2010, 01:23 PM | #7 |
RCC Addict Join Date: Mar 2007 Location: MS Gulf Coast
Yea mine came perfect in stock form. I did just take out about 1/4" to lower them a little and now they seem a little stiff but the new tire/wheel combo does not have weights in them where my previous set up did. I think if you put 2 to 3 oz in each front wheel you should be fine. Axial does offer a variety of spring rates as options so maybe experiment with some of those. I will be doing this as soon as get some.
01-22-2010, 03:38 PM | #8 |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
I'm thinking of doing what MRC guys do and using the stock bump stops inside the shock body instead of outside to limit the suspension travel and get the truck to sit lower. This truck would look great slammed over 1.9 Rok Lox |
01-22-2010, 06:39 PM | #9 |
Rock Crawler Join Date: Apr 2009 Location: Pa
I was lifting a tire with travel still left in the shocks with the stock SCX-10 springs. I put 40mm white soft springs on all 4 corners with the red 20mm springs. http://www.tcscrawlers.com/Axial-Rac...6-p-17331.html |
01-22-2010, 09:02 PM | #10 |
Quarry Creeper Join Date: May 2009 Location: Chilliwack, B.C. Canada
my springs have finally broken in after 2 weeks and now i can cycle all suspension easily
