02-01-2010, 11:12 AM | #1 |
Pebble Pounder Join Date: Mar 2009 Location: Grants Pass, OR
| Removing bumpstops on stock shocks.
Converted the plastic steering links over to aluminum the other night, and while I was at it I went ahead and removed the bumpstops on the shocks. Holy Hell!!! The difference is night and day! I have been wheelin a pile of rocks at my house for a few weeks, and I took it back out after removing the stops and couldn't believe the difference it made. This def a must do mod when you first buy a SCX.
02-02-2010, 09:02 AM | #2 | |
Newbie Join Date: Jan 2010 Location: cheltenham
02-02-2010, 09:58 AM | #3 |
Rock Stacker Join Date: Nov 2009 Location: southern ok
I just used a razor and cut them off.
02-02-2010, 10:51 AM | #4 |
Rock Crawler Join Date: May 2008 Location: Sumter, SC
Or you can remove the spring, spring cup, then take the shock end off. The bump stop will come off then. You can save it for later!
02-02-2010, 11:02 AM | #5 |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
02-02-2010, 11:09 AM | #6 |
Pebble Pounder Join Date: Dec 2005 Location: MODESTO
02-02-2010, 11:30 AM | #7 |
Yep, just unbolt the shock from the axel, remove the spring stop and springs, then unscrew the rod end from the shock shaft, slide the bump stop off and reassemble. Took maybe 5 mins.
02-02-2010, 12:15 PM | #8 |
Rock Crawler Join Date: Apr 2009 Location: Pa
Taking off the bump stops works great unless you have a Lexan body you don't want to rip the hell out of with the tires.
02-02-2010, 12:20 PM | #9 |
02-02-2010, 01:30 PM | #10 |
I only removed the bump stops from the rear suspension on my Honcho. It helped a lot and now the tire barely squishes into the flatbed. Even with the bump stops installed up front, the tires still rub; it would probably be much worse without them.
