02-13-2010, 11:11 PM | #1 |
Newbie Join Date: Oct 2009 Location: So Cal
| Stock TR ESC overheating
I've been having this problem lately. The only aftermarket items I have on my SCX10 TR is a HiTec 645mg servo and a Spektrum SR3000 receiver. I run my truck for about 5 to 10 minutes and when I feel the top of the heatsink and ESC itself, they're extremely hot! I'm using a 7 cell 5100 mah nimh battery. |
02-14-2010, 01:36 AM | #2 |
Newbie Join Date: Oct 2009 Location: Spokane, WA
I'm using a 6C 3800 on mine with no problems. Try a 6C and see if it still gets too hot.
02-14-2010, 06:03 AM | #3 |
Quarry Creeper Join Date: Jan 2009 Location: East Mids, UK
What is the ESC designed to handle?? On Axial's website it says the TR requires a 7.2volt (6cell) pack. If it can take a 7cell (8.4V) pack it will usually say so. That goes for all manufacturers. Check your owner manual, but I'm guessing that the stock ESc is only designed to take 7.2 volts, not the 8.4V you are putting through it. IF it can take 8.4v, then I would say there is a problem with the ESC. Do you have a temp gun to measure how hot it actually is? |
02-15-2010, 11:10 PM | #4 | |
Quarry Creeper Join Date: May 2009 Location: Ogden, Utah
02-16-2010, 12:30 AM | #5 |
I'm only asking because I can't find it on Axial's website, but what are the specs on the stock ESC that comes with the truck?? Input voltage etc. |
02-16-2010, 03:03 AM | #6 | |
Quarry Creeper Join Date: Sep 2005 Location: Geneva, FL
link to esc on tower. http://www3.towerhobbies.com/cgi-bin...?&I=LXULR4&P=7 | |
02-16-2010, 05:52 PM | #7 |
Pebble Pounder Join Date: Nov 2009 Location: Kingsport, TN
I had the same trouble from my TR's esc., you could literally smell it if there wasn't much wind blowing or if you were running it inside. Replaced it with the Traxxas XL-5 waterproof esc, haven't had a problem yet. Everything else is bone stock, running a 6-cell. Good luck Last edited by umop apisdn; 02-16-2010 at 05:54 PM. |
