03-25-2010, 06:04 PM | #1 |
Newbie Join Date: Mar 2009 Location: Philippines
| rc4wd OEM rims on SCX10? Roxlox on proline rims? Plis help:)
Guys, i need help I have tried searching the forum for quite some time but i still havent seen a thread discussing my concern. If you can direct me to a thread discussing this concern, it will be highly appreciated! tnx! 1. Does the rc4wd rims match the SCX10 wheel hubs? - i believe it does not... so how do i make it fit? And how can i make it secure so that i can play scale crawling and not worry about wobbling wheels. Any DIY stuff? 2. If ever i will use the stock Proline eight shooter wheels on a RC4wd Rox lox (both 1.9) will i have an issues with installing the beads on the wheel? Thanks! -Miker Last edited by msdelr; 03-25-2010 at 10:26 PM. |
03-25-2010, 06:59 PM | #2 |
Rock Crawler Join Date: Nov 2009 Location: OKC, ok
the oem wheels are pin mount. take off the hex, leave the pin, put on wheels. simple as pie bro ;)
03-25-2010, 07:41 PM | #3 |
Rock Stacker Join Date: Dec 2009 Location: midland
| Ahh, not quite that simple boss. Actually when you go to put the oem wheels on the scx10, the pin bosses on the oem wheels are to deep. So when you put them on and tighten the nut the wheels won't budge. Poor design in my opinion. What I did to fix it was cut up a body clip into small pieces and put them on each side of the pin boss in the aluminum hub. I used grease to hold them in when I installed the wheels, so they didn't fall out. Tighten the wheel nuts up and you will be good to go. |
03-25-2010, 07:43 PM | #4 | |
03-25-2010, 07:53 PM | #5 | |
Quarry Creeper Join Date: May 2009 Location: Reno
Mine worked just fine, didnt have to mod anything, i do have HR high Clearance Knuckles on tho. | |
03-25-2010, 08:18 PM | #6 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Umm... didn't RC4WD released a new version with a 12mm hex? Or they are going to soon.
03-25-2010, 08:32 PM | #7 |
Rock Crawler Join Date: Jun 2009 Location: Colorado Springs
03-25-2010, 08:33 PM | #8 |
Well they need to get crackin' then. I'd buy some(2.2 & 1.9) with hex's for sure.
03-25-2010, 08:51 PM | #9 |
Pebble Pounder Join Date: Apr 2009 Location: lake saint louis
i have the 1.55 on my scx10 pin style and they are just fine also. my understanding is rc4wd changed the pin mount on most of their wheels and dont cut the groove in the hub as deep saw that on their site a while ago. i would think they are fine. and the 1.55 are a hex mount now also. but mine are the old pin style.
03-25-2010, 10:00 PM | #10 |
Rock Crawler Join Date: Dec 2009 Location: Ontario Canada
03-25-2010, 10:06 PM | #11 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
My sets that I have had have required no modifications on Axial axles. Take off the hex, put on the wheel, bolt up and go |
03-25-2010, 10:19 PM | #12 |
Could have been a fluke set that we made wrong.
03-25-2010, 10:31 PM | #13 |
Tnx for the help! i hope theyll introduce 1.9 OEM rims with hex's soon.
03-25-2010, 10:50 PM | #14 |
Quarry Creeper Join Date: Jan 2006 Location: North Charleston
what about getting the 1.9 to seat, i have been having trouble getting mine to mount on a set of 1.9 rock creepers.
03-26-2010, 09:27 AM | #15 |
I dont see whats wrong with pin mounts. I have 2 sets, one on my Honcho and the other on my YJ. Seem fine to me
03-26-2010, 06:31 PM | #16 |
Rock Stacker Join Date: Aug 2008 Location: Winnipeg
The RC4WD steel wheeels are the best bang for the buck! Hands down!
03-26-2010, 09:42 PM | #17 |
04-03-2010, 10:29 AM | #18 |
Pebble Pounder Join Date: Oct 2004 Location: anytown usa
I just got 1.9 OEm wheels and i am having the problem where you cant tighten them down or they wont spin...not happy here. I really dont want to be cutting up body pins and mickey mousing things together. WTF! |
04-03-2010, 11:27 AM | #19 |
Rock Crawler Join Date: Jan 2007 Location: UK
Did you buy the whees recently from RC4WD? I think are two versions of the billet pin hub on the back of the wheel but I dont know which one is the latest one. Last edited by Katan; 04-03-2010 at 11:33 AM. |
04-03-2010, 12:31 PM | #20 | |
are you using stock axial steering blocks? a friend of mine has the CKRC high steer knuckles and he had the same problem. bolt them up to some stock axial ones and they were fine. | |
