05-18-2010, 10:18 AM | #1 |
Newbie Join Date: Oct 2009 Location: Anchorage
| Front Leaf Spring kit on Honcho?
I just installed the RC4WD leaf spring kit with the RCBros springs and now my wheelbase is a little bit shorter, enough to where the tire hits the body. Anyone else have this problem? The rear shackles are pointing in the right direction, I tried switching the leafs around to see if that moved the axle forward, but it didn't. I really don't want to trim the fenders to fit the tire. To fix some of the slop that happens at the leaf where the bolt connects to the shackle I used 2 flanged pipes AX30450, I had to cut them down a bit to fit in the leaf, but 2 pipes on each eye is a perfect bushing for the spring, no binding at all. |
05-18-2010, 10:51 AM | #2 |
Rock Crawler Join Date: Sep 2008 Location: Bakersfield
yes the spring kit will do that to the honcho b/c the front links are longer than the original and this kit was made to keep the wb the same as the original kit @ 11.5"
05-18-2010, 04:05 PM | #3 | |
Pebble Pounder Join Date: Sep 2008 Location: Anniston
the quick fix is to drill body post holes about 5mm forward of the original body post hole! | |
05-18-2010, 04:29 PM | #4 |
Thought about that too, but it seems the bumper sticks out too far already.
