05-20-2010, 06:33 AM | #1 |
Newbie Join Date: May 2010 Location: Virginia Beach
| Links Kit
Hello everyone. I am currently trying to upgrade a AX10 to a scale SCX10 and need some help with link selection. I was just going to buy the TR LINKS upgrade but everyone seems to be out of them. Any tips on how to select the right ones?
05-20-2010, 07:42 AM | #2 |
Rock Crawler Join Date: Jan 2006 Location: coventry, ct
| links
decide what wheelbase you want to run and start measuring! have all ur mounting mounts (4 link plates and trusses), what ur gonna run for rod ends so all you have to do is figure out link length. running 98s lower and 91s or alittle short for uppers seems to b common. i just bought a handful of 98s,91s and started measuring, cutting and tapping. good luck. |
05-20-2010, 10:02 AM | #3 |
Newbie Join Date: Apr 2010 Location: Rocklin
Check out this thread. I listed pretty much every part you would need. Hope it helps! Honcho 4 link Recipies So I got the parts in yesterday (CKRC is great by the way!) and started bolting stuff on. Now on to what does and DOES NOT work. The rear was a snap, 98mm links top and 106mm links on the bottom with the stock Axial 4 link truss. Works great no issues and suspension is everything you want in a 4 link with an improved pinion angle. Now on to the front, what a royal pain in the ARSE, 98mm bottom links work just fine as advertised BUT 91mm links on the top are WAY too long stock servo mounting will not work with this setup!!! |
