06-14-2010, 12:07 PM | #1 |
Rock Crawler Join Date: Apr 2010 Location: America
| Motor/ESC help
need a good motor/esc combo for my honcho. I want plenty of torque with just the right amount of wheel speed for around a 75-125 bucks. I also don't have a sodering iron is that problem or can the wires be spliced? (and it needs to be ran off a 6 cell 5000 mah nimh battery) |
06-14-2010, 12:46 PM | #2 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
You can get a good cheap soldering iron from radio shack for around 10 bucks. A soldering iron really is a must have in this hobby. For the controller I recommend the holmes hobbies torque master for 100 dollars and a cheap silver can 35t from rc4wd or even the axial 27t. The ESC is overkill right now but will allow you to run whatever brushed motor/battery combo you like in the future and is also fully programmable via castle link. An alternate setup would be a Tekin FXR 35t combo or a CC sidewinder with a 35t or 27t motor. ESC's: http://holmeshobbies.com/product.php...4&cat=2&page=1 http://www.rpphobby.com/product_p/tektt2106.htm http://www.rpphobby.com/product_p/csesdw.htm Motors: http://rc4wdstore.com/2/index.php?cPath=90 http://www.rpphobby.com/product_p/intscm3501.htm Even a Traxxas Titan motor would work okay:Motor/ESC help http://www.rpphobby.com/product_p/tra3785.htm |
06-14-2010, 06:35 PM | #3 |
Pebble Pounder Join Date: Jun 2009 Location: Red Lion
i run a novak rooster with a 35t lathe motor, i have descent wheelspeed, torque, and a good drag brake.
06-14-2010, 07:33 PM | #4 |
thanks for the help buddy not sure what ima do yet but all i no is that the axial esc aint cuttin it with that 27t. I could survive with it but it has no drag brake
06-21-2010, 01:55 AM | #5 |
Rock Stacker Join Date: Apr 2010 Location: San Diego
If you stick a 35 or higher turn motor on there with a 14T pinion, there will be enough motor/gear braking, that you can get by with the stock ESC.
06-21-2010, 04:36 AM | #6 |
Pebble Pounder Join Date: Jun 2009 Location: Shenandoah Valley, VA
I have a Reedy StockStar 27T, 12t pinion with stock esc and getting good motor drag brake. The Reedy has the FB9 magnets. I would prefer a 35T motor but this will do for now.
06-21-2010, 07:56 AM | #7 |
Holmes Hobbies 30t best motor for the scx-10 IMO with 15/87 gearing its not super fast but has loads of tourqe so you can use a little taller gearing
