06-15-2010, 08:50 PM | #1 |
Rock Stacker Join Date: Jun 2009 Location: charleston
| proline blazer body???
How well does the proline blazer body fit on the scx10 not the cgr body! If you have please post need ideas thanks?
06-15-2010, 09:28 PM | #2 |
Pebble Pounder Join Date: Apr 2008 Location: spring hill
will fit fine but what i dont like about proline is that they make all there bodies not wide enough so the tires king of stick out i like the hpi bronco and jeep bodies better
06-15-2010, 09:32 PM | #3 |
Rock Crawler Join Date: Aug 2009 Location: Thomasville, NC
| x2.... |
06-15-2010, 10:53 PM | #4 |
Pebble Pounder Join Date: Apr 2009 Location: lake saint louis
do some searching you will have to shorten the wheel base but it is very easy to do. I did one it is called Harley Quinn's k-5
07-09-2010, 09:29 AM | #5 |
Rock Crawler Join Date: Jul 2010 Location: SLC
Mine bolted right up without any mods
07-09-2010, 11:41 AM | #6 |
if you look on here you will see that someone has asked to see pics of your k-5 on another thread. I am a little uncertain on something MY k-5 blazer body has a 270mm wheel base, pro-line says it is supposed to be 285, I believe that to be incorrect, unless they have stretched their body, on my stock scx10 kit I used 74.5mm pipes on the lower and 50mm posts on the upper and removed the 6mm spacer from the Y-link, that made my wheel base perfect for the body. I think pro-line has a typo on their site. alf says he didnt do anything but if you check the other thread it appears he hogged out the front and rear fender wells to get it to match up closer. search for harley quinn's k-5 blazer you can see what i mean.
