06-18-2010, 03:08 PM | #1 |
Quarry Creeper Join Date: Jan 2010 Location: USA
| Honcho steering bind?
I have a new Honcho TR and have run into a problem out of the box. When the front suspension is compressed, the screw which hold the steering link to the servo horn gets jammed agains a cross brace on the chassis. Has anyone else run across this?
06-18-2010, 03:11 PM | #2 |
yup demel it, and watch because the stering link with hit the chassis too it you try to lift it up or use a short servo arm and it will limint flex
06-19-2010, 04:12 PM | #3 |
The Dremel fix worked. I carved out a nice section of the cross brace. I can't see any drawbacks other than I shouldn't have needed to do this to a new RTR.
06-19-2010, 04:49 PM | #4 |
| yes you are right that it shouldnt have needed to be done, but they used the same chassis and braces as the scx-10 short wheel base kit thats why
06-20-2010, 03:04 PM | #5 |
Pebble Pounder Join Date: Jun 2009 Location: Shenandoah Valley, VA
I removed the stock link and used a Rustler steering link attached to the back side of servo arm and right side steering knuckle. I didn't like the sharp angle with the short stock link.
