06-19-2010, 05:51 PM | #1 |
Newbie Join Date: Apr 2010 Location: Florida (239)
| A few questions.
Whats up guys. Planing on buying an scx kit (regular) soon and with it a dx3e and an fxr/35t combo. The dx3e includes a servo (S200) and it is rated at about 100oz. In. At 6 volts. Would this be good enough or should i go for something a bit more powerful? (Traxxas 2075, hitec 645mg) any input or reccommendation is welcome. Thanks Mike. |
06-19-2010, 06:42 PM | #2 |
Rock Crawler Join Date: Jan 2006 Location: coventry, ct
| servo
just go ahead and bolt it on the axle and c how it does. u can always switch out later if ur looking for more power. goodluck
06-19-2010, 09:01 PM | #3 |
06-19-2010, 09:06 PM | #4 |
Rock Crawler Join Date: Feb 2010 Location: Hayesville
Iused it on my AX10 comp truck with 7.5 oz in each front wheel with sedonas and it lasted 3 weeks
06-19-2010, 09:15 PM | #5 |
RCC Addict Join Date: Oct 2008 Location: Tyler, TX
Better to go metal gear from the get go and avoid issues. The traxxas servos suck and either strip gears constantly, burn out, or both.
06-19-2010, 09:26 PM | #6 |
Rock Crawler Join Date: Apr 2010 Location: America
ah its ok but u will want a stronger one the traxxas one is good but will strip but u need bout 250 oz to be satisfied
06-19-2010, 10:41 PM | #7 | |
Mike Last edited by Crawler20; 06-19-2010 at 10:43 PM. | |
06-19-2010, 11:31 PM | #8 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
250 is overkill on a scaler, unless ur plannin on weighing it down with lots of tube work. Metal gears are always a plus , but that will get you by till buget allows a better one. Just dont add tomuch weight and dont try to move rocks with it.
06-19-2010, 11:34 PM | #9 |
Also, Im running the 645 in my honcho with no problems.
06-20-2010, 07:34 AM | #10 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
Run the 645. I have never had a problem with them on my scalers....
06-20-2010, 08:09 AM | #11 |
I took the advice and ordered a 645 also
06-20-2010, 08:35 AM | #12 |
Rock Crawler Join Date: Nov 2009 Location: Southern, IN
The Hitec 645MG is hands down the best servo for the dollar. |
06-20-2010, 09:14 AM | #13 |
RCC Addict Join Date: Dec 2007 Location: On The Lake
You can never have servo with too much torque.... Buy the best servo you can afford I run a Airtronics 94780M in my Hilux (423 Oz/In @ 6v) and a HiTec 7955TG (333 Oz/In @ 6v) in my Honcho... |
06-20-2010, 09:46 AM | #14 |
I agree with matt above. I have never put a servo too powerful in my scx. Having a servo with over 300oz of torque makes a huge difference in driveability. While something around 150oz will work fine, more is always better. |
06-20-2010, 08:41 PM | #15 |
So since ur on a budget ..................... Get the 645. Not disagreeing Matt, Im running the same servo you have on ur honcho on my SSS. Just he is on a budget so Im assuming the $110 is outa the question.
06-20-2010, 08:51 PM | #16 | |
Tower Hobbies has a 333 Oz/In servo for $85 which is an alternative to "name brand" servos. I think it's actually made by HiTec, but I'm not sure... http://www3.towerhobbies.com/cgi-bin...&I=LXPHD6&P=ML | |
