Thread: Anyone got a front motor mount?
Old 07-21-2010, 09:30 AM   #1
Default Anyone got a front motor mount?
If I understand correctly this the GCM front motor mount will only work on the axial ax-10 frame and not the scx frame due to its taper?
http://gcmachine.ca/index.php/shop/motormounts
Has anyone ever tried to move the motor assembly forward on an scx and installed a tranfer case where the old motor assembly was?
gomery12 is offline   Reply With Quote
Old 07-21-2010, 09:32 AM   #2
i would think that having the servo over that far would cause interference with the servo and frame rails.
jthellfire911 is offline   Reply With Quote
Old 07-21-2010, 10:26 AM   #3
I guess I may have to switch to a cross canyon chassis to get it to work.
Old 07-21-2010, 10:33 AM   #4
why not just use the metal plate that comes on the axial axles and mount that to your frame to make a frame mounted servo setup??? nice and easy bull bolt right up to the existing holes.
Old 07-21-2010, 11:23 AM   #5
http://gcmachine.ca/index.php/rcstuff/brute
take a look at the motor mount and t-case (12th and 13th photo down), that is what I am asking about. Wondering if someone had a setup on the scx chassis like that. Because of the taper, I don't think it can be done on the scx chassis and therefore would have to get the cc chassis. I want to move the motor assembly forward so I dont have to make any changes to the bodies interior to keep it scale. I have the new bright JK.
So, it looks like I will be ordering some parts on payday!
Old 07-21-2010, 11:44 AM   #6
oh ok. i was thinking servo mount.. not motor haha my bad. i wouldnt see a problem. you may need to set the motor up just a little but i'm not 100% sure.
Old 07-21-2010, 12:30 PM   #7
R2j
SORRCA Committee Member
R2j's Avatar
Here's my FJ using an R2 trans and Killer T-case.
T-case mount to stock SCX skid
Mount for R2 to SCX chassis. I've done this similar mount with an Axial trans for a customer. The R2 set up requires that the steering servo be mounted on the right side or across the chassis in front of the motor.
R2j is offline   Reply With Quote
Old 07-24-2010, 11:06 PM   #8
That is sick! I just got the R2 trans and now I think I may have to find away to do this. I may have to remove the servo now that I mounted it in the framrails. Love this hobby!
vthcbbr is offline   Reply With Quote
