07-21-2010, 12:51 AM | #1 |
Pebble Pounder Join Date: Jun 2010 Location: Burien
| MIP CVD/ Spur gear clearance solutions?
Hi everybody, I finall got a set of MIP CVD center driveshafts for my SCX10 (formerly a Dingo). The rear CVD rubs the spur gear at full compression of the suspension. I was wondering if I should: A) Remove the slipper clutch and go direct drive like an AX10 (and if so do I need any special parts?) B) Go to a smaller pinion/spur combo (will any 48 pitch spur fit?) Thanks in advance! |
07-21-2010, 07:45 AM | #2 | |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
07-21-2010, 08:37 AM | #3 |
Rock Crawler Join Date: Sep 2007 Location: Petaluma
get rid of the slipper clutch,i personaly dont like slipper clutch's on my crawler's
07-21-2010, 09:20 AM | #4 |
Quarry Creeper Join Date: Apr 2008 Location: Racine
Don't slide the collar all the way on to the output of the tranny. I just had to move mine out about 2mm and it was good to go. Locktite that retaining screw in and you're all set.
07-21-2010, 01:28 PM | #5 |
RCC Addict Join Date: Feb 2008 Location: tauranga north island new zealand
07-21-2010, 05:12 PM | #6 |
Quarry Creeper Join Date: Feb 2008 Location: Australia
I run a 91t spur on a non slipper clutch tranny with the MIP's with no problems. Possibly 93 would be ok, if you want to get rid of the clutch.
07-22-2010, 02:35 AM | #7 |
Thanks for the help. I tried sliding the collar back, but it still was too close. I ended up switching to an 84 tooth spur and smaller pinion. That slipper clutch might still be going away though!
