09-05-2010, 06:15 AM | #1 |
Rock Stacker Join Date: Aug 2007 Location: Switzerland
| Honcho 4 Link. Upper Links how long
Hi Guys My Honcho is still on its way. Maybe another week. This will be my second build and this time I would like to give the Honcho a 4 Link Setup in the back. I really dont know if its any better, because in the SCX10 TR the three links works fine. But I got this 4 Link Part left from my SCX10 TR and want to use it this time. I tried to find some information about the upper links. But could not find how long the need to be. Could anyone of you give me the length of the upper links. Than I could start my mill an make waiting time a little bit shorter. Thanks. |
09-05-2010, 09:36 AM | #2 |
Rock Crawler Join Date: Nov 2009 Location: Southern, IN
the upper links need to be the same length as the lowers for the correct pinion angle. |
09-05-2010, 10:25 AM | #3 | |
Newbie Join Date: Jul 2010 Location: The Garage, away from the woman
Having the pinion pointed upwards a bit makes for a better driveline angle although on an RC crawler I doubt it really impacts performance. | |
09-05-2010, 12:02 PM | #4 | |
so 106mm is the length of what my uppers are | |
09-05-2010, 12:17 PM | #5 |
Rock Crawler Join Date: Aug 2009 Location: milton,wv
as the axial web site said,i just added the 35mm post to the stock 60mm post and it worked out great for my honcho,its all located in their blog section with all the part numbers and everything you need for the conversion
09-05-2010, 12:36 PM | #6 |
| thats onky 95mm, i thnk thats for the OG scx-10 kit. and that on a honcho must have some terrible pinion angle!
09-05-2010, 05:30 PM | #7 |
I wanna be Dave Join Date: Jul 2008 Location: Southwestern, Ohio
They need to be about "SEARCH BUTTON" long! |
09-05-2010, 05:38 PM | #8 |
Rock Crawler Join Date: Nov 2008 Location: SoCal
09-05-2010, 05:50 PM | #9 |
Pebble Pounder Join Date: Jan 2009 Location: Yacolt, wa
Isn't the rule of thumb the uppers need to be atleast 70% as long as the lowers?
09-05-2010, 05:58 PM | #10 |
| no real rule of tumb for upper link length with rc, a lot of people like to have same length or the uppers slightly shorter, honestly anything from 98mm-106mm will work best with the honcho
09-05-2010, 06:04 PM | #11 |
RCC Addict Join Date: Sep 2008 Location: Mccalla,Al
my uppers are 98 mm. Perfect. |
09-05-2010, 07:00 PM | #12 |
RCC Addict Join Date: Feb 2008 Location: your back yard
From everything I've read from the SEARCH is that make them the same as lowers.
09-05-2010, 07:47 PM | #13 |
| no problem with pinion angle at all,works out fine,thats whats needed for the honcho,go read the blog
09-05-2010, 09:12 PM | #14 |
Pebble Pounder Join Date: Jun 2010 Location: Burien
If you are using the stock Axial 4 link truss, the uppers generally will be about 6-8mm shorter than the lowers. If you make the uppers the same lenght as the lowers, you will re clock the axles, giving you a lot of negative caster in the front (which can actually give you more steering), and will raise the u-joints above the lower links (good for ground clearance. You will probably want to check your driveshafts to make sure that they can compress far enough as not to limit suspension travel. The best thing to do is get some 8-32 steel all thread, a bag of Traxxas Revo rod ends and experiment and find out what works best for you.
09-05-2010, 10:14 PM | #15 |
RCC Addict Join Date: Jan 2009 Location: Crawlifornia
Same length as ur uppers. Works PERFECT!!! If it doesn't I'll buy them from you.
09-07-2010, 06:56 AM | #16 |
Thank you for all the information. Greetings |
