09-14-2010, 08:40 PM | #1 |
Tossin' Salad Join Date: Jun 2010 Location: Petaluma
| gunnar Axle beef toobs
Are you tired of breaking your C off of the plastic housing? I have a solution for you. As many of you may know, I am making some toobs that give your axle alot more strength around the Cs. After some investigative work, it has been realized that the stock dog bones can be used, provided you do not use VP zero ackermann knuckles. The bearing of the knuckles pushes the stub in too tight. http://www.rccrawler.com/forum/showt...10#post2624410 Casey Last edited by KC_JoNeS; 09-29-2010 at 09:21 PM. |
09-14-2010, 09:53 PM | #2 |
Rock Stacker Join Date: Apr 2010 Location: canada
what kind of cvd's can i use then?
09-14-2010, 09:54 PM | #3 |
09-16-2010, 03:36 PM | #4 |
can you send me a link of one please
09-18-2010, 12:28 AM | #5 |
RCC Addict Join Date: Jul 2008 Location: San Diego
Can the toobs be moded to make the stock axles work?
09-18-2010, 12:42 AM | #6 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
09-18-2010, 08:51 AM | #7 |
| My investigation up front was done with VP zero ackermann knuckles. This, ultimately, was the main problem. I have tested with some other knuckles and found the issue to be non-existent. Casey Last edited by KC_JoNeS; 09-29-2010 at 09:22 PM. |
09-29-2010, 09:22 PM | #8 |
UPDATE INFO ABOUT THESE TOOBS> These will work with stock dog bones...provided you do not use VP zero ackermann knuckles. Casey |
