Thread: shock questions?? on my scx10
Old 10-05-2010, 10:15 PM   #1
Default shock questions?? on my scx10
i had a ax10 till i disasembled it ......now im biulding a scx10 with the 12.3 wheelbase .....wat kinda shocks would be good for some beatin on the rocks?? since my ax10 shocks are a lil to big
nissan7 is offline   Reply With Quote
Old 10-06-2010, 09:27 AM   #2
90-100mm shocks
2500hdon37s is offline   Reply With Quote
Old 10-06-2010, 05:34 PM   #3
i'm running associated sc10 rear shocks on the front and rear of my honcho. gained about 1/2 inch of lift. found them new on ebay for $2.00
a set plus freight, new in package
stick-boy-rick is offline   Reply With Quote
Old 10-06-2010, 08:02 PM   #4
thank you all very much
Old 10-07-2010, 02:56 PM   #5
I like my stock SCX10 shocks, but im runnin two of them with Traxxas big-bore shafts to gain a little flex. I wouldnt hesitate to go after another set of stockers if I needed to!
Matt
66sprint6 is offline   Reply With Quote
Old 10-07-2010, 09:56 PM   #6
ok thanks ....i ll prob do that... this truck seems like it doesnt flex as good as my other scx10 for some reason
Old 10-07-2010, 09:58 PM   #7
i use the traxxas rear shocks x4 for more articulation ,i think they are 100m?
SwampDawg is offline   Reply With Quote
Old 10-08-2010, 01:32 AM   #8
it still is confusing me.
on the rc4wd site they have 100mm scale shocks but they are 75mm eye to eye.
what are the stock axial shocks? eye to eye.
I am looking for shocks that are a little bit longer than the stock axial shocks to get a little bit more articulation
murky123 is offline   Reply With Quote
Old 10-08-2010, 01:38 AM   #9
90mm
reason i use TRX 100mm XL shocks (Stampede/Slash rears)
only good use i could find for the stock 90mm shock......bumpsteer for my rig
Old 10-09-2010, 02:41 AM   #10
what aftermarket shocks are just a few millimeters longer than the stock axial ones?
I only wanna gain about 0.4 inch extra lift so that I will have a little extra articulation. I plan on keep running the 1.9 tyres, no 2.2 tyres for me.
Old 10-09-2010, 03:02 AM   #11
The Pro-Line scaler shocks are sweet but pricey . With the threaded adjustment ring, you can dial in some lift. You may also be able to install longer ball ends to give you added height. They are buttery smooth and look great.
TrailDawg362 is offline   Reply With Quote
Old 10-09-2010, 05:26 AM   #12
yeah but how much longer are those proline shocks?
I do like the smoothness of the stock axial ones.
i have no need for smoother shocks but a little bit longer would be nice
I would love to see a comparison chart about the uncompressed length
stock axial
proline
junfac
rc4wd
