01-01-2011, 01:14 AM | #1 |
Newbie Join Date: Nov 2010 Location: Guam
| shocks sizes
whats better to run on my honcho 90,100,or 110 scale shocks from rc4wd what are you guys running?
01-01-2011, 01:24 AM | #2 |
Rock Crawler Join Date: Apr 2010 Location: America
well the stock ones are 90mm but if ur lookin for lift id say 100mm
01-01-2011, 06:21 AM | #3 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
From reading here i think the 90mm rc4wd shocks are smaller then the stocks because its 90mm total and not eye to eye. So the 100mm would be the way to go with minimal differance in hight.
01-01-2011, 10:11 AM | #4 |
Quarry Creeper Join Date: Nov 2010 Location: Queen Creek, AZ
You can run 100mm shocks and end up at the same height as with the stock shocks. I run losi 4" crawler shocks with 2-3 drops of oil in each one. The rear shock collars are threaded down 1/4 way, and the fronts 1/2 way. Im sitting the same as before, but my articulation has improved alot over stock. I can rest any wheel ontop of a pop can, and the other three wheels stay planted firmly on the ground. End rant, haha. |
01-01-2011, 02:55 PM | #5 | |
01-01-2011, 04:07 PM | #6 |
They are just called "losi 4" crawler shocks" They are badass! A set of 4 is like $46 from rpphobby.com Just type losi crawler shock in rpp's search bar. If you buy them, run them with 2-3 drops of oil in each shock. Its a perfect setup. Mounting them is easy too. Use the axial stock shock link on the ends of the losi shock shafts, the losi spring perch fits snug and flush with the axial shaft link, everything else works fine. After you do that , the bottoms will mount just how the stock shocks did on the axle. For the top use the stock axial screw, stock axial shock spacer, and use the losi black plastic shock ball mount thingy. After that the top of the shocks mount like the stock ones did. If you need help, let me know, ill post pictures. |
01-01-2011, 04:48 PM | #7 | |
Pebble Pounder Join Date: Dec 2007 Location: CA
However, when you change to Losi, do you have the problem with the servo link ( the small link above the drag link ) hit the chassis when full compress? Because the stock shock has the rubber to limit the shock not to make the servo link hit the chassis when full compress. Hope you understand what I mean. Thanks. Last edited by flybird; 01-01-2011 at 04:50 PM. | |
01-01-2011, 05:01 PM | #8 |
Pebble Pounder Join Date: Aug 2010 Location: claremont... for now
those losi shocks are bad ass but they are not scale if ur looking for scale that is |
01-01-2011, 06:09 PM | #9 | |
Ive looked at the problem, and in all honesty, its 1/8" of travel you miss out on on the one side due to the link hitting the frame when the shock is fully compressed. Nobody will ever notice that when your out crawling. | |
01-01-2011, 07:06 PM | #10 | |
01-01-2011, 08:57 PM | #11 |
can you post a pic of your rigs articulation with the losi?id love to see it
01-01-2011, 10:27 PM | #12 |
Sure, ill take pics, and post them in this thread tomorrow.
01-02-2011, 02:59 AM | #13 |
Quarry Creeper Join Date: Jul 2010 Location: netherlands
| losi 4" shocks articulation
here you see my 4 inch losi crawler shocks. I filled them up with 40wt oil. I like my setup a little firm. |
01-11-2011, 04:36 PM | #14 | |
Pebble Pounder Join Date: May 2005 Location: Long Island NY
I like the sounds and looks of this set up, I'll be ordering some myself! http://www.rpphobby.com/product_p/losb1439.htm Thanks Last edited by monsterman; 01-11-2011 at 04:40 PM. | |
01-11-2011, 07:02 PM | #15 |
Rock Stacker Join Date: Sep 2010 Location: Abington
I nearly choked when i first looked at the picture with the tape measure... WOW 14 inches of flex, how big are those tires.... yes i know it's metric |
01-16-2011, 08:48 PM | #16 |
Rock Crawler Join Date: Jan 2007 Location: Northern Wyoming
I'm thinking of getting some 120mm shocks and run them semi droop with 2.2 TSLs. Anyone run something similar?
