01-01-2011, 03:31 PM | #1 |
Newbie Join Date: Jan 2011 Location: lavalette ,WV
| idk whats wrong
well i got my scx10 tr honcho for christmas and haven't been able to take it out side the first few days were great but now when i turn my truck on it will drive for about 4 or 5 feet then stop and the front wheels start acting weird and the lights do weird things and when i try to drive it bearly goes and stops. also my charger says my battery is good and ready the charger is an MRc super brain 820 battery is an patriot r/c 2000 mah7.2v. any help would be appreciated this is my first rc crawler / good truck .
Last edited by rock-gobbler 77; 01-01-2011 at 03:34 PM. Reason: needed to add more |
01-01-2011, 03:50 PM | #2 |
Quarry Creeper Join Date: Jan 2009 Location: East Mids, UK
When you say the front wheels are acting wierd, are they twitching from side to side? To me it sounds like a radio problem. Have you got the antenna extended on the Transmitter (controller)? Have you got the same channel crystal in both the transmitter and reciever? Is the Antenna wire on the reciever damaged at all? Have you tried charging the battery again? Have you checked all the plugs on the reciever? Are the batteries good in the transmitter? (if you accidentally left it switched on they might be dead. Easy to do) I don't have experiance with the charger that you have, but I have heard of chargers that think the battery is fully charged, but actualy it isn't. If you put the battery back onto charge you can double check that it is fully charged. Because you say that the front wheels are acting wierd it sounds like the radio system is glitching. Either something isn't connected properly or you are getting interferance. I would check the above and see if you notice anything. Last edited by eemmaaxxxx; 01-01-2011 at 03:56 PM. |
01-01-2011, 04:32 PM | #3 |
Quarry Creeper Join Date: Sep 2010 Location: Gettysburg
When the truck stops and won't move. Will it move once you pick it up and hit the throttle? If so then you need a bec. But it may be like stated above
01-01-2011, 05:10 PM | #4 |
Now when I turn the truck omit just goes with out me holding the gas button I'm going to hobby land tomorrow to get it looked at will post what they say bout it
01-01-2011, 07:39 PM | #5 |
Quarry Creeper Join Date: Apr 2009 Location: Akron, IN
Not trying to sound like a smart ass but you are turning the radio on FIRST, right? If you turn the truck on without the radio on it will go full throttle without you touching anything. Also check your Throttle and Steering Trims on your radio.
01-01-2011, 07:43 PM | #6 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
We have alot of people come into out store who have the same problems. They forget to unravel the RX antenna from the RX box, also make sure the Transmitter is on first and the ESC arms before you drive or it will cause issues
01-01-2011, 07:44 PM | #7 |
Yes it is on when I turn the truck on and I've not missed with the trims never have
01-01-2011, 11:33 PM | #8 |
Rock Crawler Join Date: Apr 2010 Location: America
i can tell u right now its not a major problem i bet if u take it outside and turn it on with frsh bats in tha radio it wont glicth
01-01-2011, 11:35 PM | #9 |
01-02-2011, 10:09 AM | #10 |
Quarry Creeper Join Date: Jun 2010 Location: Taos, New Mexico
Could be the ESC too, if its the rtr version.
01-02-2011, 10:41 AM | #11 |
Yea it's the rtr one
01-02-2011, 11:18 AM | #12 |
Any update? Want to post a pic of your truck and have you checked everything suggested? Have you read the manual through?
01-02-2011, 04:20 PM | #13 |
Went to hobby land and everything checked out fine it was I had a completly dead battery and the charger was defected so got a new charger and took my truck out for abou an hour had to come in cuz I was froze
