01-02-2011, 08:16 PM | #1 |
Quarry Creeper Join Date: Oct 2009 Location: Hudson
| Honcho vs SCX wheelbase ?
How different is the Honcho wheelbase vs the SCX? What would need to be changed to fit both the Jeep Cherokee and the Toyota body on it? Thanks in advance. RIZ |
01-02-2011, 08:21 PM | #2 |
RCC Addict Join Date: Dec 2007 Location: Moncton, NB, Canada
Honcho is 12.3" and OG SCX10 is 11.4". You'd need to change the links to alter the wheelbase. You can either buy them or make your own, as for the measurements I don't have those written down or do I remember them, but I'm sure somebody else will be able to provide those for you. |
01-02-2011, 09:34 PM | #3 |
Quarry Creeper Join Date: Dec 2010 Location: Canada
You can purchase the honcho kit, and it comes with extra front links in the package. Swap those front links with the longer back ones, and your wheel base is the same as the scx10. ITs exactly what i did, and no i fitted the hilux body at no extra cost
01-02-2011, 10:14 PM | #4 |
Are the shorter Honcho front links 91mm by chance? RIZ |
01-02-2011, 11:25 PM | #5 |
Newbie Join Date: Oct 2010 Location: Pacific NW
The OG 11.4" wb had 91mm front/rear, the Honcho kit has 98mm+106mm front/rear giving it a 12.3"wb
01-03-2011, 12:54 AM | #6 |
Quarry Creeper Join Date: Jan 2009 Location: East Mids, UK
If you're running 3link then the 3 link connector has spacers front and rear on a Honcho which you remove if converting to 11.4wb. That sorts the upper links.
01-05-2011, 02:55 PM | #7 |
Rock Stacker Join Date: Dec 2010 Location: Seattle
Great info thanks for heads up, plan on taking my stock Hancho, a different route and every bit of info is helpfull. Can't waite to start the build. -RCB |
