01-03-2011, 01:07 AM | #1 |
Newbie Join Date: Jan 2011 Location: Crewe, Cheshire, UK
| Dingo, modifyed and rebodied - Landrover 101
I have been in modelling years and years. mostly RC Boats but also a off road fan owning a Landrover's 1:1 and trialing them, so when I accidently came across a RC Crawler Landrover bodied which at first I though was real! - I had to get one. First I got a SCX Dingo straight away modifications had to be done. (Aug 2010) BEFORE AFTER I was going to get a Landrover Defender hardbody but money got tight so decided to build a Landrover 101 forward control body from scratch. Last edited by Tom@Crewe; 01-03-2011 at 01:16 AM. Reason: add more pic's |
01-03-2011, 07:13 AM | #2 |
RCC Addict Join Date: Sep 2009 Location: Bradenton
nice i realy like the after pic great work |
01-03-2011, 07:43 AM | #3 |
Rock Stacker Join Date: Nov 2010 Location: uk
Its awesome.....i followed your build on UKRCRC.com....real good job Tom |
01-03-2011, 10:53 AM | #4 |
Newbie Join Date: Sep 2010 Location: jersey city
why two battery's ?
01-03-2011, 12:12 PM | #5 |
Quarry Creeper Join Date: Jan 2009 Location: East Mids, UK
| Becuase it wants to be an EMaxx! Nice work. The 101 is really really well built. I did a double take when I first saw it. Where did you get the thread plate for the rear tub on the 90? Last edited by eemmaaxxxx; 01-03-2011 at 12:15 PM. |
01-03-2011, 12:14 PM | #6 |
01-03-2011, 01:27 PM | #7 |
I have two batteries for a longer run time and adds weight, a little more weight is better in a scaler it works the suspension better. The tread plate is from the local model shop its plastic though. http://www.antenocitisworkshop.com/m...l?limit=36&p=2 |
01-03-2011, 06:47 PM | #8 |
I joined the Band! Join Date: May 2009 Location: lake county ,florida
that is different if you ask me
01-03-2011, 07:24 PM | #9 | |
so both batterys are powering 1 esc and motor ? if so i want too know how its done | |
01-03-2011, 08:21 PM | #10 | |
Quarry Creeper Join Date: Feb 2009 Location: Orangevale
Here is a great article on how to do it....It's called running the batteries in parallel....if you run the batteries in series, you actually double voltage instead of run time...(that can be dangerous for your ESC and anything else that cant take the higher voltage!!!) GL | |
01-04-2011, 09:04 AM | #11 | |
| Quote: Quote: ok so if i run two 7.2v 6 cell nimh batterys in parallel it would = 7.2v but with more capacity (amp hours) correct ? how would i charge this , is it now a 12 cell battery ? what affect does this have on the batterys themselves if any ? | |
01-04-2011, 12:39 PM | #12 | |
For charging, you would need a series connector to make it a 12cell pack. I don't know about charging in parallel but I'm not sure it would work. Charging LiPO's is a different ball game because the cells need to be balanced as they are charged. If you want to charge 2 packs at a time, first your charger must be capable of 12 cell charging, and they would need to be connected in series. You then tell your charger it's a 12 cell pack. Hope that makes sense Thanks for tread plate info Tom! | |
01-04-2011, 03:33 PM | #13 |
thanks for all the help about the batterys guys love your idea tom@crewe - i will be following your dual battery idea and there mounting positions. |
01-05-2011, 12:29 PM | #14 |
To start with I just mounted the two batteries and connected them normally and used one at a time but then rewired them like this. and this way you charge them one at a time, no special parts or chargers needed. If you accidently connect a charged battery and a flat battery there could be quiet a fast flow of power from one to the other hence the fuse protection. |
