01-03-2011, 01:11 AM | #1 |
Pebble Pounder Join Date: May 2006 Location: Brentwood/Bay Area
| Methods of mounting body
Ok so, how are most of you guys mounting your lexan bodies without drilling holes for the body posts? I tried to fab up a system with velcro on the existing body mounts, but its not working well at all haha
01-03-2011, 01:22 AM | #2 |
RCC Addict Join Date: Dec 2007 Location: On The Lake
I glued up a couple pieces of flat delrin, used the stock front mounts and some velcro. Simple (no holes in the body) and works pretty well. I'll post up pics later today if you want.....
01-03-2011, 01:48 AM | #3 |
Maybe you did something similar to me. I just glued cut retangles of a dvd case on top of the body mount posts and then put velcro on that, but it doesnt work well enough. If the body gets hung up on a rock, it just comes off.
01-03-2011, 02:05 AM | #4 |
| Couldn't tell ya, but I've been doing that for the past 4 years or so and haven't had problems |
01-03-2011, 08:20 AM | #5 |
Quarry Creeper Join Date: Sep 2010 Location: Gulf Coast
Velcro always works for me! |
07-10-2011, 12:34 AM | #6 |
Rock Stacker Join Date: Dec 2010 Location: Australia
how do attach the Velcro to the body, so it doesn't peel the paint off
07-10-2011, 05:40 AM | #7 |
Rock Crawler Join Date: Aug 2009 Location: I'm a michigan boy can you feel that!
07-10-2011, 06:17 AM | #8 |
Pebble Pounder Join Date: May 2011 Location: Bettendorf, IA
| How much velcro did you use? maybe you don't have enough to hold well.
07-10-2011, 07:40 AM | #9 |
Quarry Creeper Join Date: Jun 2011 Location: arcadia
07-10-2011, 09:04 AM | #10 |
Pebble Pounder Join Date: Feb 2011 Location: indianapolis
I use pieces of alum that I clip to the stock post and 4 pieces of velcro gorrilla super glued to the body and the alum
07-12-2011, 01:28 PM | #11 |
Rock Stacker Join Date: Feb 2011 Location: Los Angeles
If someone has pics to post that would be helpful. I am not understanding how to attach the plate tothe posts?
07-12-2011, 09:51 PM | #12 |
07-14-2011, 01:37 PM | #13 |
Quarry Creeper Join Date: Aug 2009 Location: Malta
velcro using original mount with a piece of styrene |
07-14-2011, 03:08 PM | #14 |
Rock Crawler Join Date: Jul 2010 Location: Great Britain
Im liking the last method , very simple but effective. On lexan is it possible to stop the paint pulling off ?
07-14-2011, 03:29 PM | #15 |
Quarry Creeper Join Date: Feb 2011 Location: San Diego
I wouldnt use velcro try using "3M Dual Lock"
07-14-2011, 05:18 PM | #16 |
Quarry Creeper Join Date: Oct 2010 Location: Grandview, IA
[QUOTE=jammindriver;3183662]How about like this? [IMG] How did you make those? |
07-14-2011, 10:24 PM | #17 |
[QUOTE=federally;3186119]I just soldered (brazed? I used a small butane torch) some brass pipe to some brass sheet. I drilled some holes through the brass pipe for the body clips to pass through. There is enough space between the posts for me to mount my esc upside down to the underside of the pad. Last edited by jammindriver; 07-14-2011 at 10:28 PM. |
07-14-2011, 10:36 PM | #18 |
I wish I knew how to do that. How hard is it to learn?
07-14-2011, 10:39 PM | #19 |
| Well, to be honest, this was my first time. But you cannot do this with a soldering iron. Has to be a torch to get the metal hot enough. I wouldn't say I'm ready to build a tuber yet...those require real welding I think.
07-14-2011, 11:21 PM | #20 |
I've seen it done with copper plumbing, sounds like the same process. Flux, solder, torch.
