01-04-2011, 08:28 AM | #1 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
| honcho kit/ax10 compatibility listing
I am building the honcho kit and am interested in upgrading to aluminum on some axle parts and am wondering if all the parts for ax10 for axles are compatible. knuckles,hub carriers, etc also want to go to a upgraded driveshaft set but am unsure which ones fit honcho since wheelbase is longer. any help appreciated |
01-04-2011, 08:44 AM | #2 |
Quarry Creeper Join Date: Jan 2004
Yep all the Alloy parts for the AX10 will interchange with the SCX10. I'll let someone else answer the drive shaft question, because I know they fit I just don't know which MIP you need? |
01-04-2011, 09:02 AM | #3 |
thanks for confirming the ax10 question!! used to have a ax10 and thought it looked IDENTICAL, but htese days you never know as the companies like to make things similar but not always the same. |
01-04-2011, 11:11 AM | #4 |
Reg AX10 MIP's fit the Honcho, do yourself the favor and get steel trans outputs while your at it. On the axle parts some knuckles won't work with 1.9 wheels, VP Zero Ackermans I know for sure won't.
01-04-2011, 11:44 AM | #5 |
| you're absolutley sure on that. hate to drop the $$$ to be wrong.
01-04-2011, 01:08 PM | #6 |
I have them on my Honcho, so ya I'm pretty sure. The Honcho wheelbase is the exact same as an AX10. Basically the only thing different between a Honcho and AX10 is the frame and shocks, they share the same exact drivetrain.
01-04-2011, 02:07 PM | #7 |
sorry mudact didn't mean to sound like I doubted you just making sure. THANKS for responding I do Appreciate it!!
01-04-2011, 09:06 PM | #8 |
No problem, I tend to come off a little harsh on the screen compared to real life at times.
01-04-2011, 09:57 PM | #9 |
Pebble Pounder Join Date: Dec 2009 Location: oregon
the links on a honcho are longer than the stock ax10 i know the rears are 106 lowers i think the fronts 91 or 96 and the uppers are different to honcho wheel base 313 mm scx10 tr is 11.4 |
