01-04-2011, 09:00 PM | #1 |
Newbie Join Date: Jan 2011 Location: Roxburough
| Honcho drive shaft issues
So i am a new owner of a honco thanks to finish line rc and all their help....but i am use to my real crawler and still learing about the scaling side, My main issue right now is my front drive shaft keeps falling off at the diff, i put thread lock on the set screw and tightend it but i am scared to over tighten it...even with the thread lock its still coming off, any ideas?
01-04-2011, 09:28 PM | #2 |
Rock Stacker Join Date: Nov 2010 Location: Big Island
The stock drive shafts are junk. The problem with them falling off is very common, do yourself a favor and pick up a set of junfac or mip drive shafts.
01-04-2011, 09:31 PM | #3 |
Quarry Creeper Join Date: Nov 2010 Location: Sarasota, Florida
01-04-2011, 10:27 PM | #4 | |
Quarry Creeper Join Date: Oct 2010 Location: West Melbourne, Florida
AX10 Punisher drive shafts | |
01-04-2011, 10:46 PM | #5 |
Pebble Pounder Join Date: May 2007 Location: Victorville
Yep been running the stock ones for about 8 months and have only had to replace two plastic shafts so far, plus I am running a VP dig. if you are losing the yoke off the shaft make sure the yoke theads are not striped or the shaft isnt rounded off where it will let it move back and forth.
01-05-2011, 11:22 AM | #6 |
Rock Stacker Join Date: Dec 2010 Location: Seattle
I have the same problem, I'll look into the junfac or mip drive shafts. Thanks -RCB |
01-05-2011, 11:31 AM | #7 |
Quarry Creeper Join Date: Jan 2004
Watch the Junfac shafts, they may be to short on the rear if your running the Honcho. Read this:Junfac Driveshafts For Honcho |
01-05-2011, 11:48 AM | #8 |
Pebble Pounder Join Date: Dec 2007 Location: CDA
I busted my stock shafts on a loose dirt climb, they suck IMO. I run Traxxas stampede shafts for now, cheap easy to get and tough. Not sure if they are long enough for the Honcho?
01-05-2011, 06:29 PM | #9 |
ill check out the mips that seems to be the big hitter around here with the guys i've talked to its just frustrating i mean it has not even seen dirt yet
01-05-2011, 06:51 PM | #10 |
Quarry Creeper Join Date: Sep 2010 Location: Maine
Mine did the same thing. I took two set screws and some gorillia super glue. Those little f***rs havnt come undone yet |
