Thread: Hiding/routing wires
Old 01-05-2011, 07:44 PM   #1
Default Hiding/routing wires
So I got the new electronics for my honcho (ESC, BEC, servo and a motor) and with all of it combined the wires are all over the place. Where are you guys routing/wrapping/hiding the wires? Pics and suggestions much appreciated!
LittleDave is offline   Reply With Quote
Old 01-05-2011, 08:04 PM   #2
MODERATOR™
EeePee's Avatar
In the box. Though I don't have a BEC in there...
EeePee is offline   Reply With Quote
Old 01-05-2011, 08:06 PM   #3
I have my receiver box at the back of my frame and most of the wires are in it. The only wires I have exposed are the motor to ESC, battery and servo extension which is ziptied to the framerail. The motor wires are also ziptied.
canadianbacon is offline   Reply With Quote
Old 01-05-2011, 11:05 PM   #4
I built a radio box out of plastic box from radio shack and using the proline ujnder tray
twistedone is offline   Reply With Quote
Old 01-06-2011, 12:12 AM   #5
Does the proline underbody work with the honcho body?
Old 01-06-2011, 12:48 AM   #6
SCALE PERFORMANCE PARTS
Locked Up's Avatar
I'm running a Radio Shack box as well.
Anything you can do to fill in the wheel wells and underside will really help keep the wires hidden and make it look more realistic.
Scroll through the first 4 posts of my SCX10 build and you'll see a big difference in how it ended up looking.
Locked Up is offline   Reply With Quote
Old 01-06-2011, 09:14 AM   #7
Im using the stock honcho box, nothing more.
Hiding wires is easy, just look at it and think about it for a second. Invest in some small black zipties.
Im running a light kit, and the only wires you can see on my rig are the esc to motor wires. (i havent gotten around to making those stealth yet)
Mega Fattie is offline   Reply With Quote
Old 01-06-2011, 10:27 AM   #8
what motor you running
discgolferlee is offline   Reply With Quote
Old 01-06-2011, 03:47 PM   #9
Tekin 45T
Heard good things about it. I'm hoping it has close to stock wheel speed cause I'm keeping the stock gearing.
Old 01-06-2011, 11:53 PM   #10
what is that motor
Old 01-07-2011, 03:22 PM   #11
MODERATOR™
EeePee's Avatar
That motor is a Fantom Rhino 55 turn. It has a larger than yer average comm (though not so much not average these days), and a 4 magnet can, which was not so average then either, but more so now. One of the slowest, smoothest starting motors I've ever encountered. It was discontinued before Fantom switched over to a larger comm Blitz motor. Fairly rare to see them.
Old 01-08-2011, 04:36 AM   #12
+1 on the floor pan. You have to cut the front lip off to fit, but it gives you plenty of space for all electronics/wiring.
Sith Lord is offline   Reply With Quote
