Thread: Suspension
Old 01-07-2011, 05:20 PM   #1
Default Suspension
i wanna lift my honcho a bit soo im thinking of going with 110s what are some good 110s that you guys are running?
TLWP is offline   Reply With Quote
Old 01-07-2011, 05:35 PM   #2
from asking this question alot on here and getting the same answer over and over i would go with the http://www.rpphobby.com/product_p/pro6060-00.htm ever tho thay are only 95mm thay are the best and the most reliable you can buy IMO and if u ask anyone else thats what there gonna say
pwnstar101 is offline   Reply With Quote
Old 01-07-2011, 06:53 PM   #3
ill give it a try..i wonder if it will give a little lift
Old 01-07-2011, 07:16 PM   #4
I just gving you my two cents and Im not bashing you just my opinion whatever you do with your rig is your business and I respect that but just for fun my friend and I but 110mm shocks on his honcho and it didnt look right at all, 95mm to 100 should be ok, but like I said what ya like is what ya like good luck bud
cmyers1 is offline   Reply With Quote
Old 01-07-2011, 08:40 PM   #5
got any pics? im thinking of some 110mm shocks too and some 2.2 tires.
AX10wannabe is offline   Reply With Quote
Old 01-07-2011, 11:16 PM   #6
SCALE PERFORMANCE PARTS
Locked Up's Avatar
Stock shock shafts are 50mm long. If you install longer ones (properly bump stopped) and longer springs (or lower the spring collars) you can "lift" the truck to various heights.
The benefit being that you keep the same amount of articulation and aren't flopping over all over.
That's how I have my H2 setup and I have been very pleased with it.
These shafts will get you about 1/2" of lift:
http://www3.towerhobbies.com/cgi-bin...?&I=LXSAN7&P=7
There are longer shafts out there (search shock shaft on tower) and you can add longer rod ends on the shocks as well.
For the longer springs, you can always use 2 of the longer style springs that come on the SCX10 shock:
http://www3.towerhobbies.com/cgi-bin...?&I=LXXGF1&P=7
Locked Up is offline   Reply With Quote
