01-20-2011, 01:59 PM | #1 |
Rock Crawler Join Date: Jul 2009 Location: Little Rock, Arkansas
| Tucking the tires in 3/8" more
I think my stock wheeled scx10 would look much better if the tires stuck out about 3/8" less on each side. I do not want to narrow the axles or anything drastic like that and I wish to keep my full turning range. Any clue as to how I can accomplish this?
01-20-2011, 02:30 PM | #2 |
simple wheels with a more inset offset.
01-20-2011, 05:47 PM | #3 |
I wanna be Dave Join Date: Mar 2007 Location: roland,ar
ditch your hexs and get the rc4wd steelies 1.9s. they just use a pin mount like the 2wd losi's and ae's. ive got a set you can tryout.. |
01-21-2011, 10:56 AM | #4 |
So what amount of offset do I need a set of wheels to have to get the desired effect? I don't even know what the offset on stock axial wheels is.
01-21-2011, 11:12 AM | #5 |
Rock Crawler Join Date: Nov 2004 Location: in a basement in Kalispell, MT
I ran hpi stock car wheels. Tires fit completely under a honcho body.
01-21-2011, 02:35 PM | #6 |
what width do you need/want to be at? any pics to help out? |
01-25-2011, 04:07 PM | #7 |
01-26-2011, 06:02 AM | #8 |
you'll want a offset as close to the outside of the wheel as possible. i.e.-the closer the hex is to the inside of the wheel(axle side)the wider of a stance you'll have,the further away the hex is from the axle the more narrow your stance will be. *=hex axle -[* ] -wide axle -[ *] -narrow *should be zero offset* pic of a wide off set wheel..hex is almost to inner ring.. narrow offset wheel.. like stang said.. hex is closer to outside of the wheel. hope i helped some... ill be getn out crawln this week,hollar if ya wanna go with. |
