01-21-2011, 06:09 AM | #1 |
Rock Stacker Join Date: Sep 2010 Location: Medway
| SCX10 Driveshaft
My driveshafts have been popping of randomly, front and back, off the trans and diffs. Well i lost the front half of the front driveshaft. And there arent any SCX10 ebay chop shops so im out of luck there. I saw these and was wondering if they fit. http://store.rc4wd.com/Scale-Nylon-P...5mm_p_818.html Thanks |
01-21-2011, 06:51 AM | #2 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
just get some mip steel shafts and never worry about driveshafts again
01-21-2011, 07:45 AM | #3 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
I agree with discgolferlee on the MIPs. If you search "drivelines" in this or the AX-10 section you will find many different options that people have used.
01-21-2011, 08:16 AM | #4 |
Rock Stacker Join Date: May 2009 Location: East Texas
Go to CKRC.COM they have what you need, from metal, to stock replacment... besta luck.. |
01-21-2011, 08:18 AM | #5 |
Newbie Join Date: Dec 2010 Location: Australia
yep. just get upgraded driveshafts as i broke my stock plastic ones even with the alloy ends cos they wore out and broke where the pin goes through..
01-21-2011, 09:48 AM | #6 |
I joined the Band! Join Date: May 2009 Location: lake county ,florida
go with metal one there are a ton of people who make them and you dont have to worry about if its gonna work or not
01-21-2011, 10:07 AM | #7 |
Rock Stacker Join Date: Jan 2011 Location: Grand Junction
yep, the stock ones are garbage, broke both of mine in a matter of 20 min my first trip out. MIP are nice but there are tons of other makers out there. J21 |
01-21-2011, 11:17 AM | #8 |
RCC Addict Join Date: Feb 2006 Location: ccxc
the junfac ones are a tad short on the scx10. Any idea what ones are longer?
01-21-2011, 11:26 AM | #9 |
Gettin’ back on the horse Join Date: Feb 2006 Location: Hoonsville
01-21-2011, 11:33 AM | #10 |
Alright thanks guys. I've had this truck since christmas and i've never had any issues with them breaking but they pop off the diffs and trans alot. So these do break alot once you get traction i guess, so i'll go with steel ones. |
01-21-2011, 11:36 AM | #11 |
So are these ones good? http://store.rc4wd.com/Gmade-Hardene...e-1_p_953.html http://store.rc4wd.com/Gmade-Hardene...e-1_p_953.html I know its integy but are they good? http://www.rcplanet.com/Integy_Drive.../INTC23151.htm Last edited by 02hawk; 01-21-2011 at 11:39 AM. |
01-21-2011, 12:43 PM | #12 |
Rock Crawler Join Date: Jan 2010 Location: Pacifica, CA.
My drive shafts have been solid since day one and my SCX10 (kit) is almost two years old now. Blue lock tight seems to do the trick. Maybe it's because I built mine and that is why they are still holding after all this time? Also what kind of motor battery set up are you using? a 3s will be to much power and will pop off the shafts everytime. I am running 2s with a 45T motor. |
01-21-2011, 01:11 PM | #13 |
Newbie Join Date: Dec 2010 Location: Parker
Wouldn't it help if he loosened up the slipper clutch a little?
01-21-2011, 01:25 PM | #14 | |
01-21-2011, 02:51 PM | #15 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
Traxxas Stampede driveshafts with Axial DS retainer rings is a cheaper alternative, but it's hard to beat MIP's .
01-21-2011, 03:48 PM | #16 |
01-22-2011, 05:52 PM | #17 |
Rock Stacker Join Date: Oct 2010 Location: Knoxville
bite the bullet and spend the coin on some decent metal shafts. from what i've read and tried the brand doesnt matter as much as how well you put them together. grab a pair, take ur time and threadlock everything and never worry about it again.
01-22-2011, 06:06 PM | #18 |
Rock Crawler Join Date: Jan 2006 Location: coventry, ct
I've been beating my Honcho with the vxl system and 3S with 0 issues. Blue lock tight and double set screws on each u joint and bingo no issues. I haven't seen a reason to.justify the $50+ for the mips. Just makesure they r line up property and tight.
01-22-2011, 10:16 PM | #19 |
Newbie Join Date: Jan 2008 Location: Asheville
01-23-2011, 05:22 AM | #20 |
Wait so AX-10 and SCX-10 driveshafts are interchangable?
