01-22-2011, 09:22 PM | #1 |
Quarry Creeper Join Date: Feb 2010 Location: Los Angeles, California, USA
| custom links?
is there a way i can get custom links? i wanna go for a land rover d90, but the links need to be 3mm shorter than the dingo links. i highly prefer aluminum ones body: http://store.rc4wd.com/110-Land-Rove...-Kit_p_18.html |
01-22-2011, 09:42 PM | #2 |
Pebble Pounder Join Date: Nov 2010 Location: Charlotte
I bought some end links from an e-revo and #8 threaded rod and 6mm brake lines cost me about 8 bucks to make 4 links with extra to make more. bought the threaed rod at Home depot and the brake line at autozone. just make sure your measurements are correct as far as the actual links. VV his post count is higher so you should take his advise over mine...I'm a newbie! lol but I'll say with what I did worked out great. Last edited by sj4x4; 01-22-2011 at 09:53 PM. |
01-22-2011, 09:51 PM | #3 |
I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
tappable aluminum tube, some long 4mm studs and some revo or jato rod ends and a 4mm tap |
01-22-2011, 09:55 PM | #4 |
RCC Addict Join Date: Mar 2009 Location: Across the street from Folsom Prison
Just came across this http://www.rccrawler.com/forum/showthread.php?t=294265 but if you want delrin R2J has them |
01-22-2011, 09:55 PM | #5 |
sounds interesting, ill give it a go one more request can someone get me measurements of the dingo rear links, both top and bottom, from tip to tip? and ill contact ajs and see how much he'd do it for Last edited by mycrors7; 01-22-2011 at 09:59 PM. |
01-22-2011, 09:58 PM | #6 |
RCC Addict Join Date: Apr 2006 Location: Brighton
3mm is close to 1/8" (3.175mm). Why not just take 1/16th of each end of your rear links for a total of 1/8" (or whatever works). There are plenty of threads in the ends of those links to let you do this if you are careful The Dingo links...crap those are the TR plastic. The kit scx 10 links are 113mm eye to eye with the rod ends. The aluminum threaded rod in the axial parts would be the 91mm ones. Those would be for the lowers. Last edited by DeaDShorT; 01-22-2011 at 10:05 PM. |
01-22-2011, 10:06 PM | #7 | |
01-22-2011, 10:09 PM | #8 |
if my post counts wher higher I would post picks of what i did and it looks and performes fine.
01-22-2011, 10:12 PM | #9 |
slobin3d has the way to do it. I would maybe just go with some allthread and the revo or jato ends until you find what length works for you, then decide if you want to try making your own out of aluminum or delrin. Or at least at that point you'd have a measurement to give to one of the vendors mentioned for what you need for your truck.
