01-27-2011, 03:48 PM | #1 |
Rock Stacker Join Date: Jan 2011 Location: United States
| Moving Time! electronics locations
ok so i have an scx-10 with the dingo body, every time i go out, the same isssue comes up- the front end is lighter than a feather, and the a$$ end tends to bury itself into anything and everything my goal in this thread is to do a reverse on the reciever box and battery tray, moving the weight to the front and essentially making a scale-looking fuel cell out of the reciever box, if anyone has already done this i would love to know how before i wing it, otherwise i will upload pics as i work on it. |
01-27-2011, 04:40 PM | #2 |
Pebble Pounder Join Date: May 2005 Location: Long Island NY
I'm thinking about moving my electronics as well. I have read a few threads where guys have either made or taken the stock rx box and moved it to the rear and made a "fuel tank/radio box" in the rear.. Looks pretty good too.
01-27-2011, 04:47 PM | #3 |
RCC Addict Join Date: Jul 2008 Location: Fox Valley WI
Mounting the battery upfront will make a huge difference, and putting the rx box in back is easy as pie. Test fit your components and go for it, you won't be sorry .
01-27-2011, 05:03 PM | #4 |
Quarry Creeper Join Date: Dec 2010 Location: orlando
here's how I did mine for now |
01-27-2011, 05:17 PM | #5 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
get some weights in the front wheels and move your battery forward
01-27-2011, 05:28 PM | #6 |
RCC Addict Join Date: Apr 2006 Location: Brighton
Do it like this: Badger's Axial SCX-10 build w/ Proline CGR body & Accessories You end up with everything out front. Only complication would be with a chassis mounted servo setup. This is by far the best method I've seen for putting thee battery up front with a stock setup. Last edited by DeaDShorT; 01-27-2011 at 05:32 PM. |
01-27-2011, 08:03 PM | #7 | |
Thats a pretty sweet way of installing the electronics. My problem at the moment is I am running a Traxxas XL5 and the cooling fins stick up to far and hit everything "tranny wise".. I will soon upgrade to another ESC & Motor Combo most likely a Novak Brush less System or Mamba Max Combo.. | |
01-27-2011, 09:28 PM | #8 |
ok i have it done havent got a chance to test for real yet but it seems to work on the carpet ok i have pics and will upload soon and explain how and what i did,
01-27-2011, 09:31 PM | #9 |
@ 08sv:: i actually kept the battery straight, i used longer screws with spacers and it actually can go through full travel without hitting the top of the servo, i was surprised at how easy it actually was
02-03-2011, 12:38 AM | #10 |
| this is before and after sorry it took so long my camera was set on a high resolution and i have to mod all the pics |
02-03-2011, 12:41 AM | #11 |
THE ONLY ISSUE is that the wires for the axial servo were too short so i am using my throttle servo off of my nitro stampede and it is weaker than sh... |
02-03-2011, 07:31 PM | #12 |
I've been laying out the electronics in my scx10 and run into the same problem. I'm going to need an extension and Y harness to run my steering and winch servo's, need the Y harness to power up the servo's from the CCBEC. I actually think my clod super comp rig was less of a mess as far as wiring |
