01-29-2011, 03:43 PM | #1 |
Rock Stacker Join Date: Jan 2009 Location: Rocksprings AKA, rock bottom
| Custome wheelbase, what drive shafts?
Yeah i searched, and found out that the mips work best but my wheel base is 12 7/8 so im not sure they will work. futher more the rear end is lengthened more than the front. the rear from output to output is roughly 5 5/8 in leangth and the front is roughly 5 3/8 to a 1/2. if any bodys got a mip set up or know about them i would appreciate any info. thanx.
01-29-2011, 04:07 PM | #2 | |
Pebble Pounder Join Date: Apr 2010 Location: Tuscaloosa
Cut the yoke off a male shaft and glue the shaft into a female shaft, making sure you have enough spine contact. You'll end up having two female shafts on each end with the male shaft (with yoke removed and glued into one) in between. Make sense? | |
01-29-2011, 06:40 PM | #3 |
Quarry Creeper Join Date: Dec 2010 Location: orlando
output - output to the bearing face? i ask cause i'm using komodo axles on my honcho and got lots of spline left in the rear. i can measure if you need?
01-29-2011, 08:22 PM | #4 |
RCC Addict Join Date: Oct 2007 Location: Kennewick, Washington
I built this little extension for the rear of my Honcho. My wheelbase is 13.250 Last edited by Cave Dave; 01-29-2011 at 08:27 PM. |
01-29-2011, 11:02 PM | #5 |
Thanx guys, i think ill go with the traxxas shafts idea, why didnt i think of that i got a million. besides i need a quick fix, i just got to mock it up and get it running befor i put the brushless setup in it and tear it to shreds, having said that, cavedave, what and how did you make that extention from. ill be needing sumtin like that for the brushless.
