01-30-2011, 02:03 AM | #1 |
Pebble Pounder Join Date: Nov 2010 Location: Alabaster
| Thinking of stretching
Okay so well the other day i was wheeling and my aluminum links broke so i said to myself could i use the links off my revo 3.3 and well i did in front and stretched it and it looks sick but ran into a problem with driveshaft length and im looking at going with punishers 150-192mm shafts. Now another problem wheels and tires what are the biggest 2.2s out there the rock crushers, the bogger look a likes or what can somebody give a link to good tire and wheel combos
01-30-2011, 06:40 PM | #2 |
Newbie Join Date: Feb 2010 Location: Knightdale
2.2 rovers on axial stock rims are not very tall but not real short
01-30-2011, 10:11 PM | #3 |
Looking for a wider and taller tire to make the scx wider because i think it needs to be wider so it want flip as easy
01-31-2011, 12:58 AM | #4 |
RCC Addict Join Date: Dec 2010 Location: middle,tn
flip backwards or sideways cause if it flips backwards that dont have anything to do with how wide it is, also rockstar wheels will give u a good wide stance and baja claws are really wide and look great on scx10 i run 1.9's and im very happy with my claws you will need to change those foam crawler innovations will hook u up with some awesome duel stage foams that will do great in all weather conditions ditch memory foam in cold weather
01-31-2011, 01:11 AM | #5 |
It flips sideways.I have weights up front and rear so it doesnt flip backwards or forward. Im wanting to try 2.2's and correct me if im wrong the SCX10 is a 12mm hex right
01-31-2011, 02:10 AM | #6 |
| correct 12mm if your flipping sideways that means you have poor sidehill are you running any scale items such as a roof rack things like that i'd try adjust my shock set-up instead of widen the stance but if u choose to widen the rockstars have a huge offset and they look sick, but i'd try playing with springs, shock weight, just test and retest adjustments see what works for ya
01-31-2011, 09:46 PM | #7 |
ok ill try to do that but i dont have any scale stuff
