01-31-2011, 12:34 PM | #1 |
Rock Crawler Join Date: Nov 2010 Location: Denver
| Length of links
I am piecing together a SCX 10 and would like to know what the stock length is for the links to make 4 link suspension? And what wheel base will that give me? I've looked in the manual but it only gives info on a 3 link set up. Thanks |
01-31-2011, 03:04 PM | #2 |
make the upper links the same as your lower links |
01-31-2011, 04:35 PM | #3 |
Rock Crawler Join Date: May 2009 Location: Queensland, Australia
Depends on what wheelbase you are shooting for. Stock SCX10 (og kit with the chevy looking body) was 91mm lowers fron and rear. (11.9" wheelbase i think) Honcho kits is 98mm front 106mm rear. (12.3" wheelbase) With 4 link you want your uppers & lowers to be the same or the uppers to be a fly shite shorter. Hope it helps man. |
01-31-2011, 07:34 PM | #4 |
Quarry Creeper Join Date: Jul 2009 Location: Long Island
I have the shorter wb scx10. On the front I installed tra2742x links top and bottom. Using the axial 4link truss, for the top links i cut 6mm brake line to 3-3/8ths. My rear 4 link is an r2j and those are pretty much the same lenght also.
01-31-2011, 07:51 PM | #5 |
Pebble Pounder Join Date: Jun 2010 Location: ocala
What body do you intend on running? I just built a rubicon here's a link scx-10 jeep I can measure up my set up, but it's a 3 link right now. I had 4 days to cet it running for a comp this past sunday so 3 links it was. I built my links out of 5/16" delrin for the lowers and 1/4" for the uppers. it's so easy to work with and if it works on my bully, then it's got to work.
01-31-2011, 08:46 PM | #6 |
02-01-2011, 08:29 AM | #7 |
Newbie Join Date: Jan 2011 Location: Milwaukee
What about the top front links using the BENDER plate?
02-01-2011, 10:55 AM | #8 |
Rock Crawler Join Date: Jan 2010 Location: [loh-key-shuhn]
| I took similar advice and ordered 106mm links to 4-link my rear on my Honcho kit and the pinion was pointed straight up. I'm using the Axial 4-link truss. From my research, I have found with the SCX-10 and Axial 4-link truss, you will need upper links approximately 11 mm shorter than the bottom. For example, if you have 106mm bottom links, you would need 95mm upper links. According to Brandon's Trail Ranger Build found here, he used 20mm post to add length to the 3-link upper links which are 60mm. That's 80mm compared to the lowers on his rig of 91mm = 11mm difference. So if you go with this set-up, you would need 35mm posts to add to the existing 60mm = 95mm. If you use another 4-link truss, I can't verify the above is true. |
02-01-2011, 01:23 PM | #9 | |
02-01-2011, 01:49 PM | #10 | |
Excuse me 0lllllll0, for hijacking your thread. 2500hdon37s, do you mind snapping a photo of your rear 4-link setup? I'll try to do the same later tonight. I could be doing something wrong. I'd rather use the parts I have instead of buying more. Thanks. | |
02-01-2011, 02:20 PM | #11 |
| No worries at all, I would like to see some pics as well.
02-01-2011, 03:17 PM | #12 | |
using all axial rod ends (in factory locations) with my own home made 106mm upper delrin links | |
02-01-2011, 06:38 PM | #13 |
Hey HD are your upper and lower links the same eye to eye? The bent one you have on the bottom is longer then the stock ones. Did you make the uppers 106mm eye to eye or the tube it self 106mm?
02-01-2011, 08:57 PM | #14 |
The lower links are stock from the honcho kit, 106mm with the rod ends per the instructions. The top links in this picture are Axial 106mm links with the chassis side rod ends from the 3-link per instructions, and axle side rod ends same as lower links. The top picture is too dark to see plainly (sorry), but you can see that the pinion is not parallel with either link. The bottom picture shows how far the axle is clocked upward. You can see some other pictures in my album here. |
02-02-2011, 03:48 AM | #15 |
Pebble Pounder Join Date: Nov 2010 Location: Camarillo
I run 98mm uppers and 106mm lowers for my JK 13" WB SCX10 The last pic the uppers look too long
02-02-2011, 04:15 AM | #16 |
When i was making mine the bottoms were too long for the top also just like btoungette. To me it seems 2500HD made the top links 106mm total end to end or eye to eye. Just the bottom tube from axial is 106mm with out the links and he added the bent link on one end which makes the bottoms a hair longer. I dont know though, but im sure he will chime in today |
02-02-2011, 07:16 AM | #17 | |
I do like how 2500hdon37s used the bent rod ends for some extra clearance. I may have to borrow that idea. (They are approximately 3mm longer than the regular Axial ones.) | |
02-02-2011, 01:34 PM | #18 |
| its a 106mm link (ie. not ETE) but the bent rod end is not long enough to have the effect that btoungette is seeing.
02-02-2011, 08:08 PM | #19 |
0lllllll0, I bet you didn't realize what you were getting into by asking your original question. Well, I did some more research and found the following:
I know I have had fun with this discussion and maybe it helps someone. 0lllllll0, keep in mind that even though we all have the SCX-10, we can have different set-ups and use different parts. That is one thing (of many) that makes this hobby fun. 2500hdon37s, Thanks for all your help also. |
02-02-2011, 11:24 PM | #20 | |
This is what makes this site and this hobby so fun, folks reaching out and sharing the information and experience. Thanks | |
