02-05-2011, 04:19 PM | #1 |
Rock Stacker Join Date: Nov 2010 Location: Jasper
| Axle Pinion Bearing pushes out
Hello, I've searched and haven't found or overlooked that problem I'm having. When I run mt truck the front pinion bearing wants to push out of the housing. Has any one experienced this or am I the only one. I plan on pulling it apart to check everything but wanted to wait till I had time to waterproof it so I only had to take it apart once. Any help to what to look for when I pull it apart would help, Thanks.
02-05-2011, 04:32 PM | #2 |
Rock Stacker Join Date: Apr 2009 Location: Gilbert, AZ
im not 100% certain but i think there is supposed to be a C-clip there......maybe someone else can chime in...
02-05-2011, 04:32 PM | #3 |
Quarry Creeper Join Date: Nov 2010 Location: weeki Wachee
yea i have that same problem i too would like to know if there s a solution to that i havent really looked into it, i shouldve when i went to steel gears. maybe a spacer in the diff would help i dont know Last edited by all_scaled_out; 02-05-2011 at 04:35 PM. |
02-05-2011, 04:41 PM | #4 |
02-05-2011, 04:47 PM | #5 |
granted, im using t-rex axles, i checked and there is a C-clip on mine, don't have my axials readily available or i would check those too..... in this pic, you can see the c-clip though |
02-05-2011, 05:57 PM | #6 |
Well from what I can tell about how easy it is to push back in I think the axle housing is just a loose fit for the bearing, it is just held by pressing it in so I going to hold it in with plumbers goop, it's the same thing I use on the bearing on my helicopter .
02-05-2011, 06:01 PM | #7 |
Quarry Creeper Join Date: Jun 2010 Location: Wheeling
you must have had those axle cases made by Mitsubishi(crank walk refence...) ahem.. try choking up on the pinion shaft with the driveshaft end once you put it all back together. i run MIP shafts and have never had this happen but with stockers it might slide on ya. also, i run the OD gears , the pinion has a lip at the end of the shaft that wont let it slip off the end unless the setscrew went byebye entirely. |
02-05-2011, 08:06 PM | #8 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
Make sure you have the gear mesh the way you like/want it and then slide your driveshaft yoke down on the pinion shaft until it just touches the pinion shaft bearing face. Tighten yoke set screw....you're done. If it works out that the set screw is not over top of the shaft flat, you can always add a few shims.. Almost every RC car manufacturer makes shims for one application or another....you just need to find ones with the right ID & OD. Do a quick search on Tower's website....you'll see what I mean. (My personal preference are the Tamiya ones as they come in sets of assorted thickness.) Narly1 |
02-05-2011, 08:11 PM | #9 |
Quarry Creeper Join Date: Jul 2009 Location: West GA, USA
I had the same problem recently. The bearing even pushed the shaft off the pinion a couple times. I pulled the bearing, cleaned out that area really well, and reinstalled. I made sure to push it in as far as possible using an old bearing. Good so far. I guess some grease made it through and lubed it up, allowing it to slide out. Last edited by 92PathSE; 02-05-2011 at 08:14 PM. |
02-05-2011, 09:40 PM | #10 |
Newbie Join Date: Mar 2010 Location: sacramento
All you need is two small drops of medium lock tight on the out side of the bearing and slide it in let it dry and your done MAKE SURE TO USE SMALL DROPS to much and it will be a pain to get it apart
