02-22-2011, 01:23 PM | #1 |
Rock Stacker Join Date: Dec 2010 Location: Concord
| scx10 drive shaft upgrade?
is there an upgrade to the plastic drive shaft? I already broke (after one day) the front drive shaft where the two pins go in to the shaft.
02-22-2011, 01:31 PM | #2 | |
Newbie Join Date: Jan 2011 Location: San Jose
Ive broken 2 sets of driveshafts before i decided to go steel and it was well worth it! | |
02-22-2011, 01:42 PM | #3 |
Rock Stacker Join Date: Sep 2010 Location: Earth
here is another driveshaft upgrade that some people do. it's cheaper than mip or other metal shafts, and easy to replace as the traxxas shafts come with 6 or so in a bag. Maxx Shafts made easy. |
02-22-2011, 01:47 PM | #4 |
Rock Stacker Join Date: Jan 2010 Location: hamilton
MIP shafts are the best |
02-22-2011, 03:38 PM | #5 |
Pebble Pounder Join Date: Sep 2010 Location: West Linn
If you dont lube the shafts after every offroad run, they will rust and get dirt in them and cause them to bind and make your scaler run slower and louder. I prefer to use the stock ones just cause its less rotational mass to the tires, so its just less stress on the drivetrain. I also had the integy shafts before and those IMO worked better than the MIP's, but still corroded at the rotational part.
02-23-2011, 02:57 AM | #6 |
thanks for the replys I ended up going to with the mips. thanks for the tip moonyjohn I will make sure to kep them clean.
